查看: 3113|回复: 6
labwindows/cvi做的将面板最前端显示的程序源码(置顶面板)
发表于 2008-6-21 19:22:24 | 显示全部楼层 |阅读模式
labwindows/cvi做的将面板最前端显示的程序源码(置顶面板),即如果有其他面板,这个面板也会最前端显示,就算此面板没有被选中,也会比其他面板前置!
最近突然想到这个东西,想试一下,这里做了一个简单的例子,希望能抛砖引玉,对需要的朋友有用,谢谢!欢迎大家有空常到CPUBBS论坛玩!
您需要 登录 才可以下载或查看,没有帐号?注册
x
发表于 2010-8-26 11:50:50 | 显示全部楼层
回复 cpubbs 的帖子
      真是太感谢您的无私奉献了,刚好能用到! 可以将主面板置顶.
但是置顶后的面板怎么恢复到原来的状态呢? 就是恢复到其他程序界面可以处于最顶层?
另外,如果主面板包含有很多子面板,那么是否可以把其中一个子面板置顶呢?我在程序中试了,好象没有变化的!
发表于 2010-8-27 09:16:07 | 显示全部楼层
自己来回答吧! 昨天找到SetWindowPos函数的原形看了下,要取消最顶层设置,只需要把参数HWND_TOPMOST换成HWND_NOTOPMOST即可:
SetWindowPos(TopPanelHandle,HWND_TOPMOST,0,0,0,0,SWP_SHOWWINDOW);   //置顶
SetWindowPos(TopPanelHandle,HWND_NOTOPMOST,0,0,0,0,SWP_SHOWWINDOW);//恢复
SetWindowPos函数的原形如下:
SetWindowPos
The SetWindowPos function changes the size, position, and Z order of a child, pop-up, or top-level window. Child, pop-up, and top-level windows are ordered according to their appearance on the screen. The topmost window receives the highest rank and is the first window in the Z order.
BOOL SetWindowPos(
  HWND hWnd,             // handle to window
  HWND hWndInsertAfter,  // placement-order handle
  int X,                 // horizontal position
  int Y,                 // vertical position
  int cx,                // width
  int cy,                // height
  UINT uFlags            // window-positioning options
Parameters
hWnd
[in] Handle to the window.
hWndInsertAfter
[in] Handle to the window to precede the positioned window in the Z order. This parameter must be a window handle or one of the following values. Value Meaning
HWND_BOTTOM Places the window at the bottom of the Z order. If the hWnd parameter identifies a topmost window, the window loses its topmost status and is placed at the bottom of all other windows.
HWND_NOTOPMOST Places the window above all non-topmost windows (that is, behind all topmost windows). This flag has no effect if the window is already a non-topmost window.
HWND_TOP Places the window at the top of the Z order.
HWND_TOPMOST Places the window above all non-topmost windows. The window maintains its topmost position even when it is deactivated.
For more information about how this parameter is used, see the following Remarks section.
X
[in] Specifies the new position of the left side of the window, in client coordinates.
Y
[in] Specifies the new position of the top of the window, in client coordinates.
cx
[in] Specifies the new width of the window, in pixels.
cy
[in] Specifies the new height of the window, in pixels.
uFlags
[in] Specifies the window sizing and positioning flags. This parameter can be a combination of the following values. Value Meaning
SWP_ASYNCWINDOWPOS If the calling thread and the thread that owns the window are attached to different input queues, the system posts the request to the thread that owns the window. This prevents the calling thread from blocking its execution while other threads process the request.
SWP_DEFERERASE Prevents generation of the WM_SYNCPAINT message.
SWP_DRAWFRAME Draws a frame (defined in the window's class description) around the window.
SWP_FRAMECHANGED Sends a WM_NCCALCSIZE message to the window, even if the window's size is not being changed. If this flag is not specified, WM_NCCALCSIZE is sent only when the window's size is being changed.
SWP_HIDEWINDOW Hides the window.
SWP_NOACTIVATE Does not activate the window. If this flag is not set, the window is activated and moved to the top of either the topmost or non-topmost group (depending on the setting of the hWndInsertAfter parameter).
SWP_NOCOPYBITS Discards the entire contents of the client area. If this flag is not specified, the valid contents of the client area are saved and copied back into the client area after the window is sized or repositioned.
SWP_NOMOVE Retains the current position (ignores the X and Y parameters).
SWP_NOOWNERZORDER Does not change the owner window's position in the Z order.
SWP_NOREDRAW Does not redraw changes. If this flag is set, no repainting of any kind occurs. This applies to the client area, the nonclient area (including the title bar and scroll bars), and any part of the parent window uncovered as a result of the window being moved. When this flag is set, the application must explicitly invalidate or redraw any parts of the window and parent window that need redrawing.
SWP_NOREPOSITION Same as the SWP_NOOWNERZORDER flag.
SWP_NOSENDCHANGING Prevents the window from receiving the WM_WINDOWPOSCHANGING message.
SWP_NOSIZE Retains the current size (ignores the cx and cy parameters).
SWP_NOZORDER Retains the current Z order (ignores the hWndInsertAfter parameter).
SWP_SHOWWINDOW Displays the window.
Return Values
If the function succeeds, the return value is nonzero.
If the function fails, the return value is zero. To get extended error information, call GetLastError.
Remarks
If the SWP_SHOWWINDOW or SWP_HIDEWINDOW flag is set, the window cannot be moved or sized.
If you have changed certain window data using SetWindowLong, you must call SetWindowPos to have the changes take effect. Use the following combination for uFlags: SWP_NOMOVE | SWP_NOSIZE | SWP_NOZORDER | SWP_FRAMECHANGED.
A window can be made a topmost window either by setting the hWndInsertAfter parameter to HWND_TOPMOST and ensuring that the SWP_NOZORDER flag is not set, or by setting a window's position in the Z order so that it is above any existing topmost windows. When a non-topmost window is made topmost, its owned windows are also made topmost. Its owners, however, are not changed.
If neither the SWP_NOACTIVATE nor SWP_NOZORDER flag is specified (that is, when the application requests that a window be simultaneously activated and its position in the Z order changed), the value specified in hWndInsertAfter is used only in the following circumstances:
Neither the HWND_TOPMOST nor HWND_NOTOPMOST flag is specified in hWndInsertAfter.
The window identified by hWnd is not the active window.
An application cannot activate an inactive window without also bringing it to the top of the Z order. Applications can change an activated window's position in the Z order without restrictions, or it can activate a window and then move it to the top of the topmost or non-topmost windows.
If a topmost window is repositioned to the bottom (HWND_BOTTOM) of the Z order or after any non-topmost window, it is no longer topmost. When a topmost window is made non-topmost, its owners and its owned windows are also made non-topmost windows.
A non-topmost window can own a topmost window, but the reverse cannot occur. Any window (for example, a dialog box) owned by a topmost window is itself made a topmost window, to ensure that all owned windows stay above their owner.
If an application is not in the foreground, and should be in the foreground, it must call the SetForegroundWindow function.
Requirements
  Windows NT/2000: Requires Windows NT 3.1 or later.
  Windows 95/98: Requires Windows 95 or later.
  Windows CE: Requires version 1.0 or later.
  Header: Declared in winuser.h; include windows.h.
  Library: Use user32.lib.
See Also
Windows Overview, Window Functions, MoveWindow, SetActiveWindow, SetForegroundWindow
Built on Wednesday, August 18, 1999
发表于 2010-8-5 16:35:59 | 显示全部楼层
发表于 2010-10-10 13:33:27 | 显示全部楼层
想了好久,终于看到是如何实现的,谢谢啦!
发表于 2010-11-27 11:16:38 | 显示全部楼层
好东西,真是太谢谢了
发表于 2016-7-11 23:48:55 | 显示全部楼层
回复
GMT+8, 2025-4-5 07:13 , Processed in 0.507465 second(s), 7 queries , Gzip On, File On.
