查看: 2136|回复: 3
程序打包问题(急需解决)
发表于 2009-12-15 10:38:08 | 显示全部楼层 |阅读模式
我在用LV8.0做可执行文件的时候,出现了以下问题:
Unable to generate preview. The following files have links to help files that are invalid. Open the files and fix the help links.
G:\Program Files\LabView8.0\安装包\instr.lib\lcwave\lcwave.llb\lcwave Initialize.vi
G:\Program Files\LabView8.0\安装包\instr.lib\lcwave\_lcwave.llb\lcwave Default Instrument Setup.vi
G:\Program Files\LabView8.0\安装包\instr.lib\lcwave\lcwave.llb\lcwave Reset.vi
G:\Program Files\LabView8.0\安装包\instr.lib\lcwave\lcwave.llb\lcwave Close.vi
<Call Chain>Error 7 occurred at ABAPI Check Help FIles.vi -> ABAPI Dist Cmp Settings to Disk Hier.vi -> ABAPI Get Settings From File.vi -> EBEP_Invoke_Build_Engine_Preview.vi -> EBUIP_Build_Rule_Editor.vi -> EBUIP_CreateNewWizard_Invoke.vi -> EBUIP_CreateNewWizard_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW:
File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux.
NI-488:
Non-existent board.
按照上面所提示的,我把G盘里那些子VI加进去,还是出现同样的错误。希望高手帮忙指点一下,感激不尽
发表于 2009-12-17 00:03:14 | 显示全部楼层
是不是程序中有用相对路径咯
 楼主| 发表于 2009-12-17 11:07:11 | 显示全部楼层
没有,我只是借鉴书上利用Subpanel实现动态载入界面的例子,通过方法节点实现子VI 的动态调用而已。
但我的程序需要控制lcwave示波器,所以调用了很多lcwave本身自带的节点,再做可执行文件时就老出现上面那种情况
发表于 2009-12-17 17:07:21 | 显示全部楼层
英文差,看不懂
GMT+8, 2026-9-29 08:37 , Processed in 0.029807 second(s), 6 queries , Gzip On, File On.
