查看: 1663|回复: 1
请假大家关于Clock的问题?!
发表于 2006-3-20 03:45:10 | 显示全部楼层 |阅读模式
AI Convert Clock—The E Series clock that directly causes ADC conversions.
AI Convert Clock Timebase—The clock that is divided down to produce the AI convert clock.
AI Sample Clock—The clock that controls the time interval between samples. Each time the sample clock ticks (produces a pulse) one sample per channel is acquired.
AI Sample Clock Timebase—The clock used as the onboard clock source of the sample clock. When the source of the sample clock is set to the onboard clock, the Sample Clock Timebase is divided down to produce the sample clock. When the source of the Sample Clock Timebase is also the onboard clock, the master timebase is divided down to produce the Sample Clock Timebase.
请教大家,这四个Clock有什么区别阿?
发表于 2006-3-21 23:33:35 | 显示全部楼层
GMT+8, 2026-9-28 12:12 , Processed in 0.021188 second(s), 7 queries , Gzip On, File On.
