查看: 654|回复: 1
哪位大虾知道cvi读.srec文件怎么读,参数怎么设置
dm3692001 该用户已被删除
发表于 2010-3-3 11:29:08 | 显示全部楼层 |阅读模式
我要往FPGA里面传一个.srec类型的文件,但CVI读出来的文件与原文件内容不符,用ultraedit看到的二进制和我读出来的数列不一样。以至于FPGA端无法对.srec文件进行解码处理。
下面是我的读文件程序,请高手指教,小妹不胜感激!
打开文件函数(自定义)
int OpenFileName(UCHAR *FileName)
int i;
unsigned char RevData;
     GetPanelHandleFromTabPage (panel_handle, RAD_PANEL_TAB, DEBUGPAGE, &fpgacfgtabhandle);
    FileStatus = GetFileInfo(FileName,&FileSize);
    if (FileStatus == 0)
     MessagePopup("错误","文件没有打开");
    else
                   sprintf (FpgaShowBuf, "文件大小 %i.\n", FileSize);
       SetCtrlVal(fpgacfgtabhandle,DEBUG_FPGACFGINFOBOX,FpgaShowBuf);
       FileHandle = OpenFile(FileName , VAL_READ_WRITE,VAL_APPEND,VAL_BINARY );
       FileBuffer = (unsigned char *)malloc(FileSize);
                   FileStatus = FileToArray (FileName, FileBuffer, VAL_UNSIGNED_CHAR, FileSize, 1,
                         VAL_GROUPS_TOGETHER, VAL_GROUPS_AS_COLUMNS, VAL_BINARY);
       if (FileStatus != 0)
       MessagePopup("错误","文件读取错误");
       else
        for(i =0;i<FileSize;i++)
         RevData = *(FileBuffer+i);
        RevData = ((RevData & 0x80)>>7)+ ((RevData & 0x40)>>5)+ ((RevData & 0x20)>>3)+((RevData & 0x10)>>1)+
         ((RevData & 0x8)<<1)+  ((RevData & 0x4)<<3)+  ((RevData & 0x2)<<5)+  ((RevData & 0x1)<<7);
        *(FileBuffer+i) = RevData;
        for(i =0;i<1000;i++)
         if ((*(FileBuffer+i) == 0xff)&& (*(FileBuffer+i+1) == 0xff)&&(*(FileBuffer+i+2) == 0xff)&&(*(FileBuffer+i+3) == 0xff))
          FileHead = i;
          break;
           FileOpend = 1;
       CloseFile (FileHandle);
      return 0;
dm3692001 该用户已被删除
 楼主| 发表于 2010-3-4 09:02:04 | 显示全部楼层
GMT+8, 2026-9-28 11:01 , Processed in 0.026029 second(s), 8 queries , Gzip On, File On.
