查看: 1357|回复: 2
TDM Streaming (TDMS) DataPlugin
发表于 2010-3-12 22:40:16 | 显示全部楼层 |阅读模式
原贴地址:http://zone.ni.com/devzone/cda/epd/p/id/3008
Downloads
Filename: nitdms20.exe
Requirements: View
This DataPlugin supports reading and writing of NI-TDM-Streaming files.
The TDMS DataPlugin installs with DIAdem 10.1, LabVIEW 8.2.1, LabWindows/CVI 8.1 (USI 1.4) or higher by default.
With LabVIEW 2009 and DIAdem 11.1 (USI 1.7) National Instruments introduced TDMS 2.0. To add TDMS 2.0 support to former versions of DIAdem, LabVIEW Storage VIs and LabWindows/CVI DIAdem Connectivity Library, please download and install the TDMS 2.0 stand-alone installer.
DIAdem 11.1 stores TDMS 2.0 files by default. Please install the TDMS 1.0 DataPlugin to allow DIAdem 11.1 to store also TDMS 1.0 files.
For more details regarding TDMS 2.0 please refer to the TDMS 2.0 FAQ.
Note:
The TDMS 1.0 DataPlugin only installs with USI 1.7 (DIAdem 11.1, LabVIEW 2009) or higher. TDMS 1.0 support is installed for former USI versions by default.
With the installation of any National Instrument software containing USI 1.7 (or higher) DIAdem, LabVIEW Storage VIs and LabWindows/CVI 8.1 DIAdem Connectivity Library will store TDMS 2.0 files by default.
File Extension:*.TDMS
Direction:Read / Write
Last Change:July 1, 2009 [2.0 / 2.2.1328.581]
发表于 2010-3-17 12:02:20 | 显示全部楼层
发表于 2010-10-10 18:14:49 | 显示全部楼层
你这个贴子上面是没有东西可以下
GMT+8, 2026-9-28 06:31 , Processed in 0.022217 second(s), 7 queries , Gzip On, File On.
