今天在NI官方找到如下问题解答:
网址为:http://digital.ni.com/public.nsf ... 2BA862576B30021955E
What Service Pack Is Installed With SQL Express 2005 in the DSC Module?
Primary Software: LabVIEW Modules>>LabVIEW DSC Module
Primary Software Version: 2009 SP1
Primary Software Fixed Version: 2009 SP1
Secondary Software: N/A
Problem:
I noticed that the LabVIEW DSC Module 2009 installed SQL Express 2005. What service pack version is included with this installation?
Solution:
LabVIEW DSC Module 2009 installs SQL Express 2005 SP1. In LabVIEW DSC Module 2009 SP1, the SQL Express 2005 installation was upgraded to SP2 on Windows XP and SP3 on Windows 7.
SQL Express 2005 was limited to SP2 on Windows XP in the LabVIEW DSC Module 2009 because of a specific but serious error that can occur when SQL Express 2005 SP3 is installed on Windows XP SP2.
Also note that SQL Express 2005 SP3 is required for installation and operation on Windows 7. If you install LabVIEW DSC Module 2009 on Windows 7, windows may prompt you to upgrade your installation of SQL Express 2005 SP1 to SP3. This upgrade will not affect the operation of the LabVIEW DSC Module and is recommended.
