查看: 1930|回复: 2
请斑竹指教一个问题!!!
发表于 2005-3-25 18:45:43 | 显示全部楼层 |阅读模式
<>#include &lt;reg51.h&gt;
#include &lt;intrins.h&gt; </P>
<>#define SDA P27
#define SCL P26
#define uchar unsigned char
sbit RS=P0^7;
sbit RW=P0^6;
sbit E=P0^5;
sbit P26 = P2^6;        //file://x1226
sbit P27 = P2^7;
sbit rst = P2^1;
void write1(void);
void write2(void);
void Wait(void);
void writeByte(uchar ucDa);
uchar readByte(void);
void write1302(uchar addr,uchar ucDa);
uchar  read1302 (uchar addr);
void set(uchar *pSecDa);
void get1302(uchar ucCurtime[]);
void analyze(void);
uchar temp;
uchar a,b;</P>
void Wait(){
uchar i;
for(i=0;i&lt;10;i++){ _nop_();}
}</P>
<P>void writeByte(uchar ucDa)  //file://送一字节数据到slave,并返回确认信号
  uchar i;
ACC=ucDa;
  for(i=0;i&lt;8;i++)
    if(ACC &amp; 0x80)
      SDA = 1;
    else
      SDA = 0;</P>
<P>    ACC &lt;&lt;= 1;
    Wait();</P>
<P>    SCL = 1;
    Wait();
    SCL = 0;
    Wait();
}</P>
<P>uchar readByte(void)  //file://接收1字节数据
  uchar i;
  uchar ACC = 0;</P>
<P>  for(i=0;i&lt;8;i++)
    SCL = 1;
    Wait();</P>
<P>    ACC &lt;&lt;= 1;</P>
<P>    if(SDA)
      ACC |= 0x01;
    SCL = 0;
    Wait();
  }</P>
<P>  return (ACC);
}</P>
<P>void write1302(uchar addr,uchar ucDa){
rst=0;
SCL=0;
rst=1;
writeByte(addr);
writeByte(ucDa);
SCL=1;
rst=0;}</P>
<P> uchar  read1302 (uchar addr)
    uchar ucDa;
    rst=0;
    SCL=0;
    rst=1;
    writeByte(addr);      /* 地址,命令 */
    ucDa = readByte();   /* 读1Byte数据 */
   SCL=1;
   rst=0;
    return(ucDa);
}</P>
<P> void set(uchar *pSecDa){
uchar i;
uchar addr=0x80;
write1302(0x8e,0x00);
for(i=7;i&gt;0;i--){
  write1302(addr,*pSecDa);
  pSecDa++;
  addr+=2;}
  write1302(0x8e,0x80);
  }</P>
<P>void get1302(uchar ucCurtime[])
    uchar  i;
    uchar  addr = 0x81;
    for (i=0;i&lt;7;i++)
         ucCurtime<i> = read1302(addr);/*格式为: 秒 分 时 日 月 星期 年 */
         addr += 2;
void analyze(void){   //十位的数的话要分两次在LCD上显示,分别是十位和各个位
a=temp&gt;&gt;4;
b=temp&amp;0x0f;}</P>
<P>  void main(){
uchar code tab1[]={0x01,0x38,0x0f,0x06} ;      /*01清除屏幕;38设置8位2行; 0f显示屏幕ON,光标ON,闪烁ON;06加一*/
uchar wtime[7]={0x31,0x31,0x31,0x31,0x31,0x31,0x33};
//{0x30,0x43,0x11,0x20,0x06,0x05,0x03};
uchar rtime[7];
uchar i;
  set(wtime);
  Wait();
    for(i=0;i&lt;4;i++)
      { P1=tab1<i>; write1()  ;  }          /* 设置初始状态  */
   P1=0x80;  write1()  ;                    /*第一行起始地址*/
  while(1){
  get1302(rtime);
  Wait();
    for(i=0;i&lt;7;i++)
     { temp=rtime<i>;
     analyze();
   P1=a; write2()  ;
   P1=b; write2()  ;}             /* 输出第一行*/</P>
<P>   P1=0x80;  write1()  ; }                   /* 光标位置*/
void write1(void)                           /*RS 为0
发表于 2005-3-26 07:52:32 | 显示全部楼层
先和仿真器调试,看看你读回来的对不对,好像感觉1302不好用,不如用1307或PCF8563好用多了!用仿真器看看读回来的数据对不对先,不要直接这样子弄,不太好调试的!
 楼主| 发表于 2005-3-26 17:53:53 | 显示全部楼层
<>好的,谢谢!我再去检查检查, 以后还得请斑竹多多指教啊.</P>
GMT+8, 2026-9-28 11:29 , Processed in 0.031940 second(s), 6 queries , Gzip On, File On.
