查看: 1009|回复: 3
我的example finder不能用了
发表于 2006-4-12 06:30:11 | 显示全部楼层 |阅读模式
打开example finder时跳出一个提示,看附件example.jpg,然后可以看到例子,但双击打不开,又弹出一个提示,看附件open.jpg<img src="attachments/dvbbs/2006-4/200641122282647631.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2006-4/200641122282647631.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
发表于 2006-4-12 06:31:11 | 显示全部楼层
<>这种情况我也试过,重启一下电脑试试看行不行,如果不行的话就卸载掉LV,然后再装上试试!如果仍然不行的话重装系统,这是绝招了!呵呵!</P>
 楼主| 发表于 2006-4-12 06:32:59 | 显示全部楼层
晕了,只发上一张,这个是打开example finder时出的提示
发表于 2006-4-12 06:33:37 | 显示全部楼层
俺看到了,嘿嘿,以前也试过!
GMT+8, 2026-9-29 07:50 , Processed in 0.041780 second(s), 13 queries , Gzip On, File On.
