查看: 1337|回复: 3
求Table 表格中增减行列的例子
发表于 2010-5-27 10:01:36 | 显示全部楼层 |阅读模式
如何 在Table 表格中增减行   并且原来的 列定义的类型不变!!
发表于 2010-5-28 08:57:35 | 显示全部楼层
Deletes one or more columns from a table control starting at the specified one-based index.
Prototype
int DeleteTableColumns (int Panel_Handle, int Control_ID, int Column_Index, int Number_of_Columns);
发表于 2010-5-28 08:57:41 | 显示全部楼层
Deletes one or more rows from a table control starting at the specified one-based index.
Prototype
int DeleteTableRows (int Panel_Handle, int Control_ID, int Row_Index, int Number_of_Rows);
发表于 2010-5-28 08:57:54 | 显示全部楼层
第一个贴子是删除列,第二个是删除行
GMT+8, 2026-9-28 08:39 , Processed in 0.030156 second(s), 6 queries , Gzip On, File On.
