查看: 693|回复: 4
[labview求助] Fattal Error:"Memory.cpp" line 342
发表于 2010-7-21 15:18:26 | 显示全部楼层 |阅读模式
LabVIEW 8.2下出现的问题,无法解决
Hi All,
            I am working in LabVIEW 8.20. In my application, i am inserting a re entrant vi (hosting a xcontrol) in a sub panel placed on the Configure VI of a TEST Express. I am opening and closing the VI refnums properly. while opening the test express by double clicking i am getting the error
and it closes the labVIEW also. What is the reason and What are the things i need to check to debug this.
Regards,
Pandiarajan R
Read More: http://www.mofeel.net/394-comp-lang-labview/30915.aspx
 楼主| 发表于 2010-7-21 15:18:57 | 显示全部楼层
 楼主| 发表于 2010-7-21 15:19:11 | 显示全部楼层
 楼主| 发表于 2010-7-21 15:23:46 | 显示全部楼层
发表于 2010-7-21 15:26:13 | 显示全部楼层
一个月之前遇到过这个问题,以前老项目的程序,大约每2天发生一次,时间不定。尝试解决N久未果,唯一收获就是LabVIEW底层看起来应该是C++写的,其实这也不奇怪,从control的对象继承就知道LabVIEW肯定是建立在面向对象的基础上的,不过它自己到8.2才出来对OOP的支持,而且支持的一塌糊涂,据说到8.6好了一点,等忙完这段时间去了解了解。。
GMT+8, 2026-9-29 04:00 , Processed in 0.048403 second(s), 7 queries , Gzip On, File On.
