查看: 501|回复: 1
[分享] Why Do I Get Error 547 When I Save For Previous Version from 2009 to 8.5?[转贴]
发表于 2010-7-27 11:10:15 | 显示全部楼层 |阅读模式
原贴地址:http://digital.ni.com/public.nsf/allkb/E24B66D8249FC02F862576A400602164
Primary Software: LabVIEW Development Systems>>LabVIEW Professional Development System
Primary Software Version: 2009
Primary Software Fixed Version: N/A
Secondary Software: N/A
Problem:
I'm using LabVIEW 2009 and I have event structures in my code.  When I try to save my code back to version 8.5 I get this error:
Fatal Internal Error : "MemoryManager.cpp", line 547
LabVIEW version 9.0
You will lose any unsaved work.  For assistance in resolving this problem, please relaunch LabVIEW, or contact National Instruments.
How can I fix this?
Solution:
This error will occur if you use an event structure in LabVIEW 2009 and try to save your code for LabVIEW 8.5.  If you have access to LabVIEW 8.6, you can use the following steps:
  • In LabVIEW 2009, navigate to File»Save for Previous Version... to save your VI in LabVIEW 8.6
  • Open your VI in LabVIEW 8.6 and navigate to File»Save for Previous Version... to save your VI for LabVIEW 8.5
If LabVIEW 8.6 is not available, you can try the following steps:
  • In each event of your event structure, document the events and options as free labels
  • Replace the event structure with a stacked sequence structure
  • Navigate to File»Save for Previous Version... to save the VI for version 8.5
  • Open the VI in LabVIEW 8.5, then replace the stacked sequence structure with an event structure and manually reconfigure the events based on your comments.
 楼主| 发表于 2010-7-27 11:10:49 | 显示全部楼层
今天版主王兄说遇到这样的问题,然后告诉我这个地址,我顺便转贴过来给大家一起分享,因为有朋友不能上国外的网站!
GMT+8, 2026-9-29 04:00 , Processed in 0.035669 second(s), 7 queries , Gzip On, File On.
