查看: 1131|回复: 3
老大帮我看看这个棘手的问题
发表于 2006-5-3 17:25:57 | 显示全部楼层 |阅读模式
<img src="attachments/dvbbs/2006-5/2006539251958706.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2006-5/2006539251958706.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
<img src="attachments/dvbbs/2006-5/2006539252733574.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2006-5/2006539252733574.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
两个case,一个信号来自内置的sine,一个来自文件,通过case切换,要求graph必须在case外边,因为有别的用。
问题就是选信号来自文件的时候,文件夹不断打开,该怎么解决呢?
发表于 2006-5-5 18:31:21 | 显示全部楼层
打开文件应该有读指定文件夹的,你看一下它的HELP,一般打开都有一个选项可以选的,是打开存在的还是咋样,你得给他一个固定的默认路径,不然他就一直提示!给了就不提示了!
 楼主| 发表于 2006-5-5 22:11:51 | 显示全部楼层
<>打开存在的文件,</P>
<>如果给个默认的,那他就不会询问,直接就读了</P>
发表于 2006-5-5 23:20:58 | 显示全部楼层
兄弟你不是就想要它不问吗?呵呵,看来我又理解错了!
GMT+8, 2026-9-29 09:11 , Processed in 0.049912 second(s), 13 queries , Gzip On, File On.
