查看: 844|回复: 1
能不能做这样个tank
发表于 2006-5-9 01:07:11 | 显示全部楼层 |阅读模式
我在做设计时要用个桶(有点像两个信号的确tank)显示三部分,即中间只要能有两个分界就行了<img src="attachments/dvbbs/2006-5/200658178059629.bmp" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'attachments/dvbbs/2006-5/200658178059629.bmp\');}" onmousewheel="return imgzoom(this);" alt="" />
[此贴子已经被作者于2006-5-8 17:08:37编辑过]
发表于 2006-5-9 04:40:27 | 显示全部楼层
<><a href="http://www.cpubbs.com/old_bbs/dispbbs.asp?boardID=4&amp;ID=13221&amp;page=1" target="_blank" >http://www.cpubbs.com/old_bbs/dispbbs.asp?boardID=4&amp;ID=13221&amp;page=1</A></P>
<>第六点!其实就是相当于自定义控件!兄弟以后发贴最好能将图片转成JPG或JPEG比较小些,这样打开的时候就比较快,你上传也可以比较快,呵呵!</P>
GMT+8, 2026-9-29 09:11 , Processed in 0.039543 second(s), 13 queries , Gzip On, File On.
