查看: 1309|回复: 0
AT29C040读写源程序
发表于 2004-11-6 02:44:07 | 显示全部楼层 |阅读模式
<>#include &lt;reg51.h&gt;
#include &lt;intrins.h&gt;</P>
<>unsigned char time;
void int_t0(void) interrupt 1 {
time++;
}</P>
<>unsigned char d; //rec data</P>
<P>bit rec(void) {
TH0=0;time=0;
while (!RI) {if (time&gt;1) return(1);}
RI=0;
d=SBUF;
return(0);
void sen(unsigned char dd) {
SBUF=dd;
while (!TI) {}
TI=0;
}</P>
<P>void wait(void) {
time=0;while (time&lt;10) {}
}</P>
<P>void wait10ms(void) {
TH0=150;time=0;
while (!time) {}
}</P>
<P>sbit ce=P3^5;
sbit oe=P3^6;
sbit we=P3^7;
sbit a16=P3^2;
sbit a17=P3^3;
sbit a18=P3^4;</P>
<P>void pro_to_card(void) {
unsigned char no,i,j;
sen(0xaa);
if (rec()) {wait();return;}
no=d;
sen(d);
no&lt;&lt;=2;
no|=0xe3;
P3=0xff;
P3&amp;=no;
i=0;
do {
  P0=i;
  j=0;
  do {
   if (rec()) {wait();ce=1;return;}
   TI=0;SBUF=d;
   P1=j;
   P2=d;
   ce=0;
   we=0;
   we=1;
   ce=1;
   j++;
  } while (j);
  wait10ms();
  i++;
} while (i);
ce=1;
}</P>
<P>void card_to_pro(void) {
sen(0x55);
no=d;
sen(d);</P>
<P> no&lt;&lt;=2;
no|=0xe3;
P3=0xff;
P3&amp;=no;
P2=0xff;</P>
<P> i=0;
do {
  P0=i;
  j=0;
  do {
   P1=j;
   ce=0;oe=0;
   no=P2;
   oe=1;ce=1;
   j++;
   sen(no);
   if (no!=d) {wait();return;}
  } while (j);
  i++;
} while (i);
}</P>
<P>
void load(unsigned int as,unsigned char dd) {
P0=as/256;P1=as;P2=dd;
ce=0;we=0;we=1;ce=1;
void erase(void) {
a16=a17=a18=0;
load(0x5555,0xaa);
load(0x2aaa,0x55);
load(0x5555,0x80);
load(0x5555,0xaa);
load(0x2aaa,0x55);
load(0x5555,0x10);
wait10ms();
wait10ms();
}</P>
<P>void unlock(void) {
unsigned char i;
a16=a17=a18=0;
load(0x5555,0xaa);
load(0x2aaa,0x55);
load(0x5555,0x80);
load(0x5555,0xaa);
load(0x2aaa,0x55);
load(0x5555,0x20);
i=0;
do {
  P1=i;
  i++;
} while (i);
*/</P>
<P>void main(void) {
SCON=0x80;
TMOD=0x21;
ET0=TR0=1;EA=1;
wait10ms();
// erase();
// unlock();
REN=1;
while (1) {
  REN=1;RI=0;
  while (!RI) {} RI=0;
  switch (SBUF) {
  case 0x55:card_to_pro();break;
  case 0xaa:pro_to_card();break;
  case 0xa5:
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   sen(0xaa);
   break;
</P>
GMT+8, 2026-9-28 04:41 , Processed in 0.021456 second(s), 7 queries , Gzip On, File On.
