查看: 1614|回复: 0
这程序为什么会有错?
xingkong_007 该用户已被删除
发表于 2006-5-14 07:12:09 | 显示全部楼层 |阅读模式
int CVICALLBACK OPEN (int panel, int control, int event,
   int o,xb=0;
   int ret;
      int i,j,k;
      int n=2;//dts文件中一个数据所占用的字节
   int max=0;
      double *Ydataa1;
   double *Ydataa2;
   float adc[2];
   unsigned char *data;
   unsigned short int *dataH;
      unsigned short int *dataH1;
      unsigned short int *dataH2;
      unsigned short int *dataL;
   switch (event)
  case EVENT_COMMIT:
   ret=FileSelectPopup ("c:\\", "*.dts", "*.dts;*.dtd", "选择驱动器文件",
       VAL_LOAD_BUTTON, 0, 0, 1, 1, pathName);
   if(ret!=VAL_EXISTING_FILE_SELECTED)
      return 0;
  InsertTextBoxLine (cHandle, PANEL_TEXTBOX, 0, pathName);
  xb=strlen(pathName);
     if(pathName[xb-1]=='S'||pathName[xb-1]=='s')
          {td=0;
           SetCtrlVal (cHandle, PANEL_CHANNEL, td);
  if(pathName[xb-1]=='D'||pathName[xb-1]=='d')
       {td=1;
  if(td==0)   //单通道
        GetFileInfo (pathName, &filesize);
        pf=(int)(filesize/(2.56*n));
  data=(unsigned char*)malloc(filesize);
       dataH=(unsigned short int*)malloc(filesize);
     dataL=(unsigned short int*)malloc(filesize);
  Ydata=(float*)malloc(filesize*n);
        Xdata=(float*)malloc(filesize*n);
        o=0;
       for(i=0;i<260;i++)
           if(pathName!=NULL)
              pts=pathName;
           else {pts[xb-3]='P';
         break;}
     o=0;
     GetFileInfo (pts, &ptsfilesize);
     fp=fopen(pts,"rb");
     fread(&T,sizeof(struct pt),1,fp);
     switch(PT.freq)  //采样频率
       case 2:SetCtrlVal (cHandle, PANEL_RINGKNOB, 0); sj=0.390625;       py=2.56;  break;
       case 5:SetCtrlVal (cHandle, PANEL_RINGKNOB, 1); sj=0.1953125;      py=5.12;  break;
       case 25:SetCtrlVal (cHandle, PANEL_RINGKNOB, 2);sj=0.0390625;      py=25.6;  break;
       case 256: SetCtrlVal (cHandle, PANEL_RINGKNOB, 3);sj=0.00390625;   py=256;   break;
       case 1280:SetCtrlVal (cHandle, PANEL_RINGKNOB, 4);sj=0.00078125;   py=1280;  break;
       case 2560:SetCtrlVal (cHandle, PANEL_RINGKNOB, 5);sj=0.000390625;  py=2560;  break;
       case 5120:SetCtrlVal (cHandle, PANEL_RINGKNOB, 6);sj=0.0001953125; py=5120;  break;
       case 25600:SetCtrlVal (cHandle, PANEL_RINGKNOB, 7);sj=0.0000390625;py=25600; break;
     switch(PT.blocks1) //数据块数
         case 1: SetCtrlVal (cHandle, PANEL_DATANUMBLE, 0); break;
      case 2: SetCtrlVal (cHandle, PANEL_DATANUMBLE, 1); break;
      case 4: SetCtrlVal (cHandle, PANEL_DATANUMBLE, 2); break;
      case 8: SetCtrlVal (cHandle, PANEL_DATANUMBLE, 3); break;
      case 16: SetCtrlVal (cHandle, PANEL_DATANUMBLE, 4); break;
    //   给X轴数据赋值
  Xdata[0]=0.00000000;        //
  for(i=1;i<filesize/n;i++)    //
  Xdata= Xdata[i-1]+sj;    //
   FileToArray (pathName, data,VAL_UNSIGNED_CHAR, filesize, 1, VAL_GROUPS_TOGETHER,
      VAL_GROUPS_AS_ROWS, VAL_BINARY); //以INTEGER为单位长度读入数祝橹??
   for(i=0,j=0,k=0;j<filesize;i++,k++)
            dataH=(unsigned short int)(data[j]);
            dataL[k]=(unsigned short int)(data[j+1]);
            Ydata=(float)(((double)((dataH+dataL*256-2048)*5000/2048)/100)*100/PT.adc);
        j=j+2;
   DeleteGraphPlot (cHandle, PANEL_WAVE, -1, VAL_IMMEDIATE_DRAW);
   DeleteGraphPlot (cHandle, PANEL_FFTWAVE, -1, VAL_IMMEDIATE_DRAW);
   DeleteGraphPlot (cHandle, PANEL_WAVET, -1, VAL_IMMEDIATE_DRAW);
   DeleteGraphPlot (cHandle, PANEL_FFTWAVET, -1, VAL_IMMEDIATE_DRAW);
   PlotXY (cHandle, PANEL_WAVE, Xdata, Ydata, filesize/n, VAL_FLOAT,
   VAL_FLOAT, VAL_THIN_LINE, VAL_EMPTY_SQUARE, VAL_SOLID, 1,
   VAL_RED);
  SetAxisRange (cHandle, PANEL_WAVE, VAL_MANUAL, 0.0, Xdata[pf]/2,
         VAL_AUTOSCALE, 0.0, 1.0);
for(i=0;i<9;i++)
   SetCtrlVal (cHandle, 52-i, 0.00);
   SetCtrlVal (cHandle, 43-i, 0.00);
for(i=0;i<9;i++)
   SetCtrlVal (cHandle, 34-i, 0.00);
   SetCtrlVal (cHandle, 25-i, 0.00);
lj=0;
/*****************双通道*************************/
  else if(td==1){//ret=FileSelectPopup ("c:\\", "*.dtd", "*.dtd;*.ptd", "选择驱动器文件",
     //  VAL_LOAD_BUTTON, 0, 1, 1, 0, pathName);
  //if(ret!=VAL_EXISTING_FILE_SELECTED)
  //    return 0;
     Ydata1=(float*)malloc(filesize/2*n);
  Ydata2=(float*)malloc(filesize/2*n);
        Xdata=(float*)malloc(filesize/2*n);
  for(i=0;i<260;i++)
           if(pathName!=NULL)
              ptd=pathName;
           else {ptd[i-3]='P';
          ptd[i-2]='T';
          ptd[i-1]='D';
         break;}
  GetFileInfo (ptd, &ptdfilesize);
     fp=fopen(ptd,"rb");
     fread(&D,sizeof(struct pd),1,fp);
  fseek (fp, 62, SEEK_SET);
  fread (&adc[0], 4, 1, fp);
     fseek (fp, 66, SEEK_SET);
  fread (&adc[1], 4, 1, fp);
     switch(PD.freq)  //采样频率
     switch(PD.blocks1) //数据块数
      //   给X轴数据赋值
  for(i=1;i<filesize/2/n;i++)    //
            Ydata=((float)((dataH+dataL*256-2048)*5000/2048))/100;
        j=j+2;
      for(i=0,j=0;j<filesize/2;i++)
            Ydata1=(float)(Ydata[j]*100/adc[0]);
            Ydata2=(float)(Ydata[j+1]*100/adc[1]);
         j=j+2;
   PlotXY (cHandle, PANEL_WAVE, Xdata, Ydata1, filesize/n/2, VAL_FLOAT,
   VAL_RED);
   PlotXY (cHandle, PANEL_WAVET, Xdata, Ydata2, filesize/n/2, VAL_FLOAT,
   VAL_RED);
   SetAxisRange (cHandle, PANEL_WAVET, VAL_MANUAL, 0.0, Xdata[pf]/2,
for(i=0;i<9;i++)
    for(i=0;i<9;i++)
lj=0;
o=0;
/****************************FFT变换****************************/
  if(td==0)   //单通道
          Img1=malloc(filesize/n*sizeof(double));
          Ydataa1=(double*)malloc(filesize*2*n);
          pydata1=(double*)malloc(filesize*2*n);
          zcdata1=(double*)malloc(pf*2*2*n);
          zc1=(int*)malloc(pf*2*2);
          for(i=0;i<filesize/n;i++)
        {Img1=0;
         Ydataa1=(double)Ydata;
         pydata1=0+(py*n/filesize)*i;
       Mag1=malloc(filesize/n*sizeof(double));
       Phase1=malloc(filesize/n*sizeof(double));
       FFT (Ydataa1, Img1, filesize/n);
             ToPolar1D (Ydataa1, Img1, filesize/n, Mag1, Phase1);
     //Mag1=(20*log10 (Mag1)-20*log10 (0.00002));
     Mag1=((Mag1*Mag1+Phase1[1]*Phase1[1])*2*sj)/(filesize/n);
     PlotXY (cHandle, PANEL_FFTWAVE, pydata1, Mag1, filesize/n, VAL_DOUBLE, VAL_DOUBLE,
       VAL_THIN_LINE, VAL_EMPTY_SQUARE, VAL_SOLID, 1, VAL_BLUE);
    SetAxisRange (cHandle, PANEL_FFTWAVE, VAL_MANUAL, 0.0, py/2.56,
      for(i=2,j=0;i<pf;i++)
        {if(Mag1>Mag1[i-1]&&Mag1>Mag1[i+1])  //&&Mag1[i-1]>Mag1[i-2]&&Mag1[i+1]>Mag1[i+2]
            zcdata1[j]=Mag1;
            zc1[j]=i;
        j=j+1;
   kt=0;
  else  //、双通道
          Img1=malloc(filesize/2/n*sizeof(double));
          Img2=malloc(filesize/2/n*sizeof(double));
          Ydataa1=(double*)malloc(filesize*n);
          Ydataa2=(double*)malloc(filesize*n);
          pydata2=(double*)malloc(filesize*2*n);
          zcdata2=(double*)malloc(pf*2*2*n);
          zc2=(int*)malloc(pf*2*2);
       for(i=0;i<filesize/2/n;i++)
        {Img1=0;
         Ydataa1=(double)Ydata1;
         Ydataa2=(double)Ydata2;
         pydata2=0+(py*n/filesize)*i;
       Mag1=malloc(filesize/2/n*sizeof(double));
       Mag2=malloc(filesize/2/n*sizeof(double));
       Phase1=malloc(filesize/2/n*sizeof(double));
       Phase2=malloc(filesize/2/n*sizeof(double));
       FFT (Ydataa1, Img1, filesize/n/2);
       FFT (Ydataa2, Img2, filesize/n/2);
             ToPolar1D (Ydataa1, Img1, filesize/2/n, Mag1, Phase1);
             ToPolar1D (Ydataa2, Img2, filesize/2/n, Mag2, Phase2);
    for(i=0;i<filesize/n/2;i++)
     {//Mag1=(20*log10 (Mag1)-20*log10 (0.00002));
       //Mag2=(20*log10 (Mag1)-20*log10 (0.00002));
       Mag2=((Mag2*Mag2+Phase2[1]*Phase2[1])*2*sj)/(filesize/n);
  PlotXY (cHandle, PANEL_FFTWAVET, pydata2, Mag2, filesize/2/n, VAL_DOUBLE, VAL_DOUBLE,
    VAL_THIN_LINE, VAL_EMPTY_SQUARE, VAL_SOLID, 1, VAL_GREEN);
  SetAxisRange (cHandle, PANEL_FFTWAVET, VAL_MANUAL, 0.0, py/2.56,
return 0;
运行是老是说什么? SetCtrlVal (cHandle, 34-i, 0.00);  该地方应该是int,而不是double ?但改过后又是double,而不是int?
GMT+8, 2026-9-28 12:12 , Processed in 0.029722 second(s), 9 queries , Gzip On, File On.
