GPU Begins With G and Ends With ULabVIEW GPU Computing unleashes the computing power of NVIDIA GPUs via the CUDA interface from within a LabVIEW application. Code that calls the GPU for computation is integrated into the native parallel execution system of LabVIEW as if it were any other multi-threaded external library function call.
The BasicsLabVIEW GPU Computing includes:
A collection of LabVIEW data types and VIs, called LVCUDA and LVCUBLAS, for interfacing with the CUDA runtime and CUBLAS Library functions.
A framework, called NICompute, that establishes a compute context in which user-define GPU functions execute
Put together these items allow LabVIEW users to:
Target multiple GPU devices from the LabVIEW diagram
Manage resources across all GPU devices
Facilitate numeric array data transfers to and from the GPU
Execute GPU process in parallel with CPU execution
Provide shared resource protection when performing GPU processes from different user libraries
Block invalid references when used on the wrong GPU device
Establish clean-up callbacks that ensure resources are freed even when the application is aborted.
