查看: 2029|回复: 2
与数据库连接的问题
发表于 2006-5-23 04:04:03 | 显示全部楼层 |阅读模式
#include "cvi_db.h"
#include <cvirte.h>
#include <userint.h>
#include "a.h"
static int panelHandle;
static int hodbc;
int main (int argc, char *argv[])
if (InitCVIRTE (0, argv, 0) == 0)
  return -1; /* out of memory */
if ((panelHandle = LoadPanel (0, "a.uir", PANEL)) < 0)
  return -1;
DisplayPanel (panelHandle);
RunUserInterface ();
DiscardPanel (panelHandle);
return 0;
int CVICALLBACK Run (int panel, int control, int event,
int a=1;
int hstate;
int rescode;
long lstatus;
switch (event)
  case EVENT_COMMIT:
     hodbc = DBConnect ("DSN=db1");
   hstate = DBActivateSQL (hodbc, "select VALUE from table1 where password=2153062");
   rescode = DBBindColInt (hstate, 2, &a, &lstatus);
   rescode = DBFetchNext(hstate);
   rescode = DBDeactivateSQL (hstate);
   rescode = DBDisconnect (hodbc);
   SetCtrlVal (panelHandle, PANEL_A, a);
   break;
return 0;
int CVICALLBACK quit (int panel, int control, int event,
switch (event)
  case EVENT_COMMIT:
    QuitUserInterface (0);
   break;
return 0;
为什么一直说找不到数据源和驱动器???我用的ACCESS?还是数据库要怎么设置?
发表于 2006-5-23 08:12:45 | 显示全部楼层
<>我看了一下这方面,它要在系统里面新建DSN,在控制面板里面的数据源里面新建一个数据源,比如你程序中的DSN=db1!所以你要新建一个DB1的数据源!</P>
 楼主| 发表于 2006-5-23 17:23:23 | 显示全部楼层
<>我已经设置了但是还是不行啊,这是什么原因?</P>
GMT+8, 2026-9-28 13:32 , Processed in 0.027555 second(s), 7 queries , Gzip On, File On.
