查看: 630|回复: 0
从数据库获取数据,竟然是空值,达人进来指导下,谢谢
发表于 2010-9-25 14:37:57 | 显示全部楼层 |阅读模式
hdbc = DBConnect ("DSN=CVI SQL TEST");
if (hdbc <= 0) {ShowError(); }//goto Error;}
  从控件读取用户名和密码
   //从数据库中获取数据进行匹配
   hstmt = DBActivateSQL (hdbc, "SELECT * FROM USER WHERE User_Name='username'");
   if (hstmt <= 0) {ShowError();}
   resCode = DBBindColChar (hstmt,1, 50, name, &name_stat,"");
   if (resCode != DB_SUCCESS) {ShowError();}
   resCode = DBBindColChar (hstmt,2, 50, psword, &psword_stat,"");
   //判断密码输入是否正确
   if ((strcmp (username, name) ==0)&&(strcmp (passwordstring, psword) == 0))
    DiscardPanel(panelHandle);
    SetCtrlVal(main_panelHandle, MAIN_PANEL_STRING,name);
    DisplayPanel(main_panelHandle);
   else
    MessagePopup ("登录失败", "用户名不存在或密码不正确!");
获取的name和psword都是空值,数据库已经连上,可以插入数据,不知道怎么回事了
数据库表如下:
User_Name         Pass_Word
杨过                   yangguo
杨康                   yangkang
GMT+8, 2026-9-28 10:23 , Processed in 0.021335 second(s), 6 queries , Gzip On, File On.
