查看: 1282|回复: 5
[求助]【如何把Graph画好的图保存下来啊】
发表于 2010-10-27 12:04:17 | 显示全部楼层 |阅读模式
如题 希望高人帮助
发表于 2010-10-28 22:06:20 | 显示全部楼层
发表于 2010-10-30 13:13:39 | 显示全部楼层
发表于 2010-10-30 18:26:22 | 显示全部楼层
要求自动就得编程,只是保存图片手工保存就是二楼说的截屏
发表于 2010-10-30 18:28:21 | 显示全部楼层
自动操作需要首先获取控件图片,用下面函数可以实现。
Obtains a bitmap image from a control and stores it in a bitmap object. You can pass the bitmap ID this function outputs to any function that accepts a bitmap, such as CanvasDrawBitmap or ClipboardPutBitmap.
You can use this function on images you create using functions such as DisplayImageFile, InsertListItem, PlotBitmap, SetImageBits, or SetCtrlAttribute with the ATTR_IMAGE_FILE attribute.
You can discard the bitmap object by passing its ID to DiscardBitmap.
Prototype
int GetCtrlBitmap (int Panel_Handle, int Control_ID, int Image_ID, int *Bitmap_ID);
发表于 2010-10-30 18:28:45 | 显示全部楼层
获取到图片后再保存到文件。
Saves a bitmap image to a .bmp file. This function returns an error if you attempt to save a transparent bitmap or a bitmap that originated from a metafile.
Prototype
int SaveBitmapToBMPFile (int Bitmap_ID, char Filename[]);
GMT+8, 2026-9-28 10:23 , Processed in 0.028786 second(s), 6 queries , Gzip On, File On.
