查看: 1531|回复: 0
16c552
发表于 2004-11-6 03:01:29 | 显示全部楼层 |阅读模式
#include <reg52.h>
#include <INTRINS.H>
#define BAUDBASE    0x30
    /***4800bps->hex***/
sfr16 DPP   = 0x82;
sbit ACC0=ACC^0;
sbit ACC1=ACC^1;
sbit ACC2=ACC^2;
sbit ACC3=ACC^3;
sbit ACC4=ACC^4;
sbit ACC5=ACC^5;
sbit ACC6=ACC^6;
sbit ACC7=ACC^7;
code unsigned char ST554_AddrHigh[4]={0x80,0x90,0xa0,0xb0};
bit fECG_Run=1;
bit fSPO2_Run=1;
初始化ST554
3.6864mhz
void Init_St554(unsigned char Location,unsigned char mBps,unsigned char mode)
  DPH=ST554_AddrHigh[Location];
  DPL=0x1;
        /***IER***/
  *(unsigned char xdata *)DPP=0x5;            /***接收保持和中
断允许.*/
  DPL=0x2;
        /***FIFO控制器***/
  *(unsigned char xdata *)DPP=0xcf;            /***set FCR.FIFO
允许,RXD复位,TXD复位,DMAmode=1,触发为14***/
  _nop_();
  *(unsigned char xdata *)DPP=0xc9;            /***set FCR.RXD
复位,TXD复位***/
  DPL=0x4;
        /***Modem状态***/
  *(unsigned char xdata *)DPP=0x8;            /***set MCR.中断
A-D开***/
  DPL=0x03;
  *(unsigned char xdata *)DPP=0x83|mode;    /***set LCR.8BIT,1STOP,ODDPARITY,选
择
特殊寄存器***/
  /***特殊寄存器已打开,设置BPS***/
  DPL=0;
  *(unsigned char xdata *)DPP=BAUDBASE/mBps;    /***时间常数***/
  DPL=1;
  *(unsigned char xdata *)DPP=0;            /***高位***/
  DPL=0x3;
  *(unsigned char xdata *)DPP=0x03|mode;    /***set LCR.8BIT,1STOP,ODDPARITY,关
特
殊寄存器***/
  DPL=0;
  ACC=*(unsigned char xdata *)DPP;            /***空读一次***/
  CY=1;
  while(CY){
    DPL=0x5;                                              /*读空*/
    ACC=*(unsigned char xdata *)DPP;            /***检查接收状态
    if(ACC0){
        DPL=0x0;
        CY=1;
    else CY=0;
检查554的接收
出口:CY=1,成功 返回接收值
     CY=0,失败
unsigned char Check0_Rxd_ST554()
  DPH=ST554_AddrHigh[0];
  DPL=0x5;
  if(ACC0){
    DPL=0x0;
    CY=1;
    fECG_Run=1;
    return(*(unsigned char xdata *)DPP);
  else CY=0;
554的发送
出口:CY=1,成功
     CY=0,失败
void Check0_Txd_ST554(unsigned char mTxd)
    DPL=0x5;
    if(ACC5){
      DPL=0;
      *(unsigned char xdata *)DPP=mTxd;
     CY=1;
    else CY=0;
检查554的接收
出口:CY=1,成功 返回接收值
     CY=0,失败
unsigned char Check1_Rxd_ST554()
  DPH=ST554_AddrHigh[1];
  DPL=0x5;
  if(ACC0){
    DPL=0x0;
    CY=1;
  else CY=0;
554的发送
出口:CY=1,成功
     CY=0,失败
void Check1_Txd_ST554(unsigned char mTxd)
  if(EX0){
    DPL=0x5;
    if(ACC5){
      DPL=0;
      CY=1;
    else CY=0;
  else CY=1;
检查554的接收
出口:CY=1,成功 返回接收值
     CY=0,失败
unsigned char Check2_Rxd_ST554()
  DPH=ST554_AddrHigh[2];
  DPL=0x5;
  if(ACC0){
    DPL=0x0;
    fSPO2_Run=1;
    CY=1;
  else CY=0;
554的发送
出口:CY=1,成功
     CY=0,失败
void Check2_Txd_ST554(unsigned char mTxd)
  DPL=0x5;
  if(ACC5){
    DPL=0;
    CY=1;
  else CY=0;
GMT+8, 2026-9-28 05:15 , Processed in 0.022280 second(s), 7 queries , Gzip On, File On.
