查看: 618|回复: 2
[分享] LabVIEW 2010 SP4 bug修补包
发表于 2010-12-8 10:44:54 | 显示全部楼层 |阅读模式
http://digital.ni.com/public.nsf ... 48E221?OpenDocument
LabVIEW 2010 f4 Patch Details
Primary Software: LabVIEW Development Systems>>LabVIEW Base Package
Primary Software Version: 2010
Primary Software Fixed Version: N/A
Secondary Software: N/A
Problem:
What fixes are included in the LabVIEW 2010 f4 patch?
Solution:
The LabVIEW 2010 f4 patch includes all of the fixes of the LabVIEW 2010 f2 patch.  Additionally it resolves the following issues. This patch is not recommended for everyone. Users that are using LabVIEW built web services are encouraged to install this patch.
IDDescription
251397LabVIEW crashes if bad wires from a multi-dimensional array are going to an array primitive.
246681LabVIEW lvwsdsc files do not generate sections correctly if the web service VI is in a subdirectory on disk.
240387Adding an xap file as always included will cause a web service to fail to deploy
243921Web services won't deploy by default and the error message is misleading (64-bit LabVIEW only)
246673Web server doesn't install clientaccesspolicy.xml into the www folder (64-bit LabVIEW only)
245129VBAI can crash when resizing a modern vertical toggle switch
Note: There wasn't a LabVIEW 2010 f3 patch that was made publicly available.
Development System and Run-Time Engine Patch
Related Links:
Developer Zone Tutorial: LabVIEW 2010 Known Issues
 楼主| 发表于 2010-12-8 10:46:45 | 显示全部楼层
发表于 2010-12-9 10:42:34 | 显示全部楼层
GMT+8, 2026-9-29 00:21 , Processed in 0.044336 second(s), 8 queries , Gzip On, File On.
