查看: 843|回复: 1
求救:有关凌阳61和labview的串口通信
发表于 2006-5-29 17:55:34 | 显示全部楼层 |阅读模式
如下是我的下位机的程序:
**********************************************定义部分**************************************************
.DEFINE                                           P_ADC_MUX_Ctrl        0x702b
.DEFINE                                           P_ADC_MUX_DATA            0x702C
.INCLUDE hardware.inc
.ISRAM
.PUBLIC      chanal_data
chanal_data:
   .DW 2 DUP(?)
.RAM
.var AD_RESULT;
*******************************************初始化,主函数***********************************************
.CODE
.PUBLIC _main
_main:
_L_INIT:
int off;
r1=0x0700;
[P_IOA_Attrib]=r1
[P_IOA_Dir]=r1;
r1=0x0000;
[P_IOA_Data]=r1
r1 = 0x0480;
[P_IOB_Attrib] =r1;
r1 = 0x0400;
[P_IOB_Dir] = r1;
r1 = 0x0000;
[P_IOB_Data] = r1;
r1 = 0x0000;                                      //设置波特率为9600bps
[P_UART_BaudScalarLow] = r1;
r1 = 0x0005;
[P_UART_BaudScalarHigh] = r1;
r1 = 0x0000;
r4 = 0x00C0;                                      //使能输入和输出
[P_UART_Command1] = r1;
[P_UART_Command2] = r4;
r1 = 0xefff;                        //设置定时器2s
[P_TimerA_Data] = r1;
r1 = 0x0005;
[P_TimerA_Ctrl] = r1;
r1 = 0x1000;
[ P_INT_Ctrl] = r1;
int IRQ;
loop:
    R1 = 0x0001;
    [P_Watchdog_Clear] = R1 ;
    call _F_UART_Read;
    goto loop;
***********************************************接受模块********************************************
.public _F_UART_Read
_F_UART_Read:
L_Check_RxRDY:
    R1 = 0x0001;
    r2 = [P_UART_Command2];           //检测是否有数据接收
r2 &= 0x0080;
JZ L_Check_RxRDY;
r1 = [P_UART_Data];                          //接收数据
cmp r1,0x0000;
je out;
cmp r1,0x0001;
je out1;
cmp r1,0x0002;
je out2;
jne out3;
out:
    r3=0x0100;
[P_IOA_Data]=r3;                  //做动作
retf;
out1:
    r3 = 0x0200;
retf;
out2:
    r3=0x0400;
retf;
out3:
    r3=0x0000;
retf;
****************************************************************发送模块*******************************************
.PUBLIC _F_UART_Write
_F_UART_Write:
L_Check_TxRDY:
R1 = 0x0001;
r2 &= 0x0040;
JZ L_Check_TxRDY;
L_Clear:
    R2 = 0x0000
R3=chanal_data
L_Chanal:
    CMP R2, 0x0002
    JE _tiao;
    R2+=1
    [P_ADC_MUX_Ctrl] = R2
R1 = 0x0001
    [P_ADC_Ctrl] = R1
    call L_AD
    [R3++]=R1
R1=0
L_DelayLoop:
    R4 = 0x0001;
[P_Watchdog_Clear] = R4;
    R1+=1
    JNZ L_DelayLoop
    JMP L_Chanal
_tiao:
      retf;
*******************************************AD子模块************************************
L_AD:                                  //AD
    R1 = [P_ADC_MUX_Ctrl]
    TEST R1,0x8000
    JZ L_AD
    R1 = [P_ADC_MUX_DATA]
    R1 = R1 LSR 4
    R1 = R1 LSR 2
    [AD_RESULT] = R1
R4 = [AD_RESULT];
    [P_UART_Data] = r4;
    R1 = R1 LSR 4
    R1 = R1 LSR 4
    R1 &=0x0003
    [AD_RESULT] = R1
    R4 = [AD_RESULT];
    [P_UART_Data] = r4;
    retf;
*************************************************中断***************************************************
.TEXT
.PUBLIC _IRQ1;
_IRQ1:
    int off
    push r1,r5 to [sp];
    call _F_UART_Write;
    r1 = 0x1000;
    [P_INT_Clear] = r1;
    pop r1,r5 from [sp];
    int irq;
    reti;
硬件部分是通过串口电平转换电路连接61单片机的b07和b10口,请问如果用labview做上位机通过串口发送程序,应该怎么写啊?下位机要接受一个四位16进制的数,应该怎么通过串口来实现啊?急用,谢谢!
[此贴子已经被作者于2006-5-29 10:14:16编辑过]
发表于 2006-5-29 21:45:52 | 显示全部楼层
<>呵呵,不好意思,凌阳的单片机没有用过!</P>
<>不过相信单片机都差不多原理,可以看看这个书:</P>
<><a href="http://www.cpubbs.com/old_bbs/dispbbs.asp?boardID=4&amp;ID=14252&amp;page=1" target="_blank" >http://www.cpubbs.com/old_bbs/dispbbs.asp?boardID=4&amp;ID=14252&amp;page=1</A></P>
<P>图片上方有下载链接的,免费下载的!</P>
GMT+8, 2026-9-29 11:40 , Processed in 0.028661 second(s), 8 queries , Gzip On, File On.
