查看: 4838|回复: 9
[labview求助] Openg能不能离线安装?
发表于 2010-12-30 10:39:02 | 显示全部楼层 |阅读模式
现在每次安装都需要通过VIPM在线进行。如果所使用的计算机不能上网,那就要自己动手拷贝相关的文件到安装路径。感觉这样的做法很简陋,请问大家有没有类似安装工具包的东西。谢谢了
 楼主| 发表于 2010-12-31 15:25:02 | 显示全部楼层
发表于 2011-1-2 11:52:40 | 显示全部楼层
Download OpenG Libraries
Step One: Download and Install VI Package Manager (VIPM)*
Please ensure that you have VIPM 2010 installed on your machine before downloading the toolkit.
Download VIPM
Before installing please note:
If you don't have LabVIEW 2009 or later, download and install the LabVIEW 2009 Run-Time Engine.
Step Two: Download OpenG Libraries Toolkit
Download and install the toolkit after installing VIPM 2010.
Download Toolkit
发表于 2011-1-2 11:53:16 | 显示全部楼层
发表于 2011-1-2 11:53:32 | 显示全部楼层
VI Package Manager (VIPM) is the recommended method to download and manage your LabVIEW Add-ons and gives you instant access to the Tools Network from your desktop.
More information
发表于 2011-1-2 11:53:55 | 显示全部楼层
如果没有提供其他包,你只能安装好再拷贝过去,这也不费时。
 楼主| 发表于 2011-1-4 16:25:14 | 显示全部楼层
想找个能安装的办法。拷来拷去的不太规范,哈
发表于 2011-1-4 20:25:37 | 显示全部楼层
拷贝是允许。不属不规范吧?自定义的是拷贝进去。
发表于 2011-1-4 21:04:02 | 显示全部楼层
 楼主| 发表于 2011-1-13 14:10:09 | 显示全部楼层
GMT+8, 2026-9-28 22:25 , Processed in 0.041596 second(s), 8 queries , Gzip On, File On.
