查看: 1169|回复: 1
求助 这个程序不知道哪里错了 抓狂
发表于 2011-3-6 16:36:50 | 显示全部楼层 |阅读模式
#include <ansi_c.h>
#include <cvirte.h>
#include <userint.h>
#include "rs232.h"
#include <rs232.h>
#include <formatio.h>
static int panelHandle;
    int comselect;
    int status;
    char info[20],readBuf[20];
int main (int argc, char *argv[])
if (InitCVIRTE (0, argv, 0) == 0)
  return -1; /* out of memory */
if ((panelHandle = LoadPanel (0, "rs232.uir", PANEL)) < 0)
  return -1;
DisplayPanel (panelHandle);
RunUserInterface ();
DiscardPanel (panelHandle);
return 0;
int CVICALLBACK Config (int panel, int control, int event,
int btlselect,jhselect,longselect,stopselect;
int comvalue,btlvalue,longvalue,stopvalue,jhvalue;
switch (event)
  case EVENT_COMMIT:
  GetCtrlVal (PANEL, PANEL_COMSELECT, &comvalue);    /* 获取端口号 */
  switch (comvalue)
   case 1:
    comselect=1;
    break;
   case 2:
    comselect=2;
    break;
   case 3:
    comselect=3;
    break;
   case 4:
    comselect=4;
    break;
   GetCtrlVal (PANEL, PANEL_BTLSELECT, &btlvalue);     /* 波特率*/
   switch (btlvalue)
    case 1:
     btlselect=1200;
     break;
    case 2:
     btlselect=2400;
     break;
    case 3:
     btlselect=4800;
     break;
    case 4:
     btlselect=9600;
     break;
    case 5:
     btlselect=19200;
     break;
     GetCtrlVal (PANEL, PANEL_JYSELECT, &jhvalue);      /* 奇偶校验*/
       switch (jhvalue)
      case 1:
    jhselect=0;
     break;
      case 2:
    jhselect=1;
     break;
      case 3:
    jhselect=2;
     break;
     GetCtrlVal (PANEL, PANEL_LONGSELECT, &longvalue);     /* 字长 */
     switch (longvalue)
      case 1:
       longselect=7;
       break;
      case 2:
       longselect=8;
       break;
      case 3:
       longselect=9;
       break;
   GetCtrlVal (PANEL, PANEL_STOPSELECT, &stopvalue);       /* 停止位*/
       switch (stopvalue)
        case 1:
         stopselect=1;
         break;
        case 2:
         stopselect=2;
         break;
    status=OpenComConfig(comselect,"",btlselect,jhselect,longselect,stopselect,512,512);     /* 打开串口*/
    if(status!=0)
       MessagePopup("Error","config failed!");
       return 0;
     SetCTSMode(comselect,LWRS_HWHANDSHAKE_OFF);      /*禁止硬件握手 */
   break;
return 0;
int CVICALLBACK Send (int panel, int control, int event,
switch (event)
  case EVENT_COMMIT:
  FlushInQ(comselect);      /* 清空串口输入队列 */
  FlushOutQ(comselect);    /* 清空串口输出队列 */
  GetCtrlVal (PANEL, PANEL_SENDTEXT, info);
  status=ComWrt(comselect,info,strlen(info));
  if(status!=strlen(info))
    MessagePopup("Error","Send data failed!");
   break;
return 0;
int CVICALLBACK Receive (int panel, int control, int event,    /* 接收数据函数 */
switch (event)
  case EVENT_COMMIT:
   status=ComRd(comselect,readBuf,strlen(info));
     MessagePopup("Error","Read data failed!");
     break;
   SetCtrlVal (PANEL, PANEL_RECEIVETEXT, readBuf);
   SetActiveCtrl (PANEL, PANEL_RECEIVETEXT);
   break;
return 0;
int CVICALLBACK Clearsend (int panel, int control, int event,    /* 清空发送框 */
switch (event)
  case EVENT_COMMIT:
  ResetTextBox(PANEL,PANEL_SENDTEXT,"\0");
   break;
return 0;
int CVICALLBACK Clearreceive (int panel, int control, int event,    /* 清空接收框 */
switch (event)
  case EVENT_COMMIT:
  ResetTextBox(PANEL,PANEL_RECEIVETEXT,"\0");
   break;
return 0;
int CVICALLBACK Quit (int panel, int control, int event,       /* 退出 */
switch (event)
  case EVENT_COMMIT:
   QuitUserInterface (0);
   break;
return 0;
 楼主| 发表于 2011-3-6 16:38:46 | 显示全部楼层
如题  我想写一个简单的rs232数据传输,但是  系统第一次是可以正确运行的  还生成了可执行文件  后来 就不行了  总是报错  似乎是数据传输的函数出了什么问题  不清楚   求教 ~~~~~谢谢
GMT+8, 2026-9-28 03:24 , Processed in 0.021522 second(s), 6 queries , Gzip On, File On.
