查看: 2969|回复: 0
CVI中如何如何用FileToArray读取所有存在txt文件中的数据
发表于 2011-4-18 09:18:55 | 显示全部楼层 |阅读模式
我现在想把存在txt文件中的数据一下全读出来然后显示在Graph 控件上,有人说使用FileToArray可以做到,但是我怎么也做不对,程序如下:
int CVICALLBACK PsmphfCallbcak (int panel, int control, int event,
    double *frdata;
int n;
switch (event)
  case EVENT_COMMIT:
    FileSelectPopup ("", "*.txt", "*.txt", "外部交流电压", VAL_OK_BUTTON, 0, 1, 1, 0, file_name);
    GetFileInfo ("file_name", &filesize);
    n=sizeof(double);
    frdata=(double*)malloc(filesize);
    FileToArray ("file_name", frdata, VAL_DOUBLE, filesize/(2*n), 2, VAL_GROUPS_TOGETHER, VAL_GROUPS_AS_ROWS, VAL_ASCII);
    PlotY (psmppanelHandle, PSMP_PANEL_GRAPH_WJ, frdata, filesize/(2*n), VAL_INTEGER, VAL_THIN_LINE, VAL_EMPTY_SQUARE, VAL_SOLID, 1, VAL_RED);
    break;
return 0;
运行的时候错误总出现在这一句:
老是说 NON-FATAL RUN-TIME ERROR:   "MainUser.c", line 1317, col 14, thread id 0x00000600:   Library function error (return value == -1 [0xffffffff]). File not found
错误见附件:
望搞人指点!非常感谢!
GMT+8, 2026-9-28 09:52 , Processed in 0.038075 second(s), 11 queries , Gzip On, File On.
