查看: 628|回复: 6
[分享] LabVIEW 2011 beta 试用
发表于 2011-4-29 16:53:34 | 显示全部楼层 |阅读模式
通过Ni网站提交了申请,获得了LabVIEW 2011 beta的试用。
We are pleased to inform you that you have been approved as a member of the
National Instruments LabVIEW Beta Program.  You should now be able to log
on to the beta website for LabVIEW at:  http://www.ni.com/beta.
The beta website is your central source for information regarding the beta
program.  The website will allow you to:
1. Download the latest Beta software
2. Report your bugs
3. See the status of your reported bugs
Within 2 work days you should have access to the private beta forum -
http://forums.ni.com/ni/board?board.id=beta13.  Please note that you must
be signed in to the NI forums to be able to access the beta forum.
Please direct any responses to labview.beta@ni.com
分享几个图片吧
 楼主| 发表于 2011-4-29 17:05:08 | 显示全部楼层
细心的朋友一定看出来的~
 楼主| 发表于 2011-4-29 17:16:39 | 显示全部楼层
看一个2011里的例子吧
 楼主| 发表于 2011-4-29 17:36:35 | 显示全部楼层
2011beta安装需要半个小时,令人比较崩溃;
好像也较多的占用CPU。在同样的计算机配置下,运行觉得没有前面的版本流畅。
 楼主| 发表于 2011-4-30 10:52:53 | 显示全部楼层
风定云远
Member
0 奖励  maybe some shortcomings选项
将该帖标记为新帖
将此帖子加入到我的{0}
将此帖加入我的{0}
高亮显示此帖
打印此帖子
将此帖E-Mail给朋友
将违规帖子报告版主
修改时间 04-29-2011 01:46 AM
1 The time for  installion is too long, about 30 minutes;
2 when LabVIEW 2011 beta running, it cost large CPU memory of PC, and makes the response of the LabVIEW is so slow.My PC :win xp 32 bit; pentuim 4, 3.06G;1.5G
已解决! 转到解答。
第 1 条消息(共 2 条) (31 查看)
  添加标记...
    在标记间使用间隔 回复
成功了! 此帖子现为已接受的解答。
smercurio_fc
Knight of NI
0 奖励  Re: maybe some shortcomings选项
将该帖标记为新帖
将此帖子加入到我的{0}
将此帖加入我的{0}
高亮显示此帖
不是解决方案
打印此帖子
将此帖E-Mail给朋友
将违规帖子报告版主
修改时间 04-29-2011 04:50 PM
Well, your PC is pretty old. A Pentium 4 is, what, 3 generations old now? That's a LONG time in terms of computer years. When I installed it on a modern computer (i7-860) the installation took maybe 10 minutes. Frankly, I think the minimum system requirements stated in the release notes (referring to the 2010 release notes, which are likely to be the same for 2011) are woefully inadequate. That seems to be typical in the software industry.
 楼主| 发表于 2011-4-30 17:28:42 | 显示全部楼层
LabVIEW 2011beta 居然把JKI 的 VIPM (VI package manager)集成进去了,看来第三方开发的东西也得到了NI的认可啊
xiaobai1989 该用户已被删除
发表于 2011-4-30 21:30:04 | 显示全部楼层
很不错,modern
GMT+8, 2026-9-28 16:08 , Processed in 0.045417 second(s), 14 queries , Gzip On, File On.
