查看: 719|回复: 2
为什么温湿度采集后显示总是溢出呢?
发表于 2011-5-8 21:00:00 | 显示全部楼层 |阅读模式
为什么温湿度采集后显示总是溢出呢?源码如下:
#include "toolbox.h"
//#include <utility.h>
#include <ansi_c.h>
#include<windows.h>
#include <rs232.h>
#include <cvirte.h>
#include <userint.h>
#include "panel.h"
#include "UPS.h"
//#include "m7.h"
#define TRUE 1
#define FALSE 0
BOOL OpenCom1_Flag=TRUE;
extern BOOL show_par_chart;
/*产生CRC校验*/
unsigned  int crc=0xffff;/*CRC校验*/
extern int UPS_start_flag;
extern int panelHandle, ups_panel, ups_panel_chart;
extern HANDLE poolHandle;
extern int Com1,Com2;
extern int flag_THD_Start;
extern char ups_analogy_state[13][100];
extern char ups_analogy_name[13][50];
extern double ac_input_volt,ac_output_volt,dc_input_volt,ac_output_current,ac_input_freq,output_freq; //码表图需要参数
void calccrc(BYTE *crcbuf,int n);
int CVICALLBACK MyThreadFunction();
//extern int Com_On_Off; //串口打开标志
int DataAcqThreadFunction(void);
void showtime(void);//显示时间
void decode_rec_buf(unsigned char *rec_buf);  //模拟参数返回值解码函数
float temp=0;
float humd=0;
char tempe[100];
char humid[100];
      unsigned char dataa[100];  //温湿度
unsigned char digcr[100]="";
    unsigned char digcr1[100]="";
unsigned int temp_crc=0;  //根据UPS返回计算的CRC值
unsigned int rec_crc=0;   //接收到的从端CRC
int i;
long int digital;
long int digital1;
int flag1=0;   //  温湿度标志位
//int num=0;
//OpenComConfig(Com1, "", 9600, 0, 8, 1, 512, 512);
   if(OpenComConfig(Com1, "", 9600, 0, 8, 1, 512, 512)<0)     //测试时候将其注释   ren 2007-10-29
    OpenCom1_Flag=FALSE;
    //MessagePopup ("警告!", "无法打开该串口设备!");   // ren  2007-10-29
    flag_THD_Start=0;
   else
    OpenCom1_Flag=TRUE;
while(flag_THD_Start)
     //SetSleepPolicy (VAL_SLEEP_MORE);
     Sleep(100);
     //获得温湿度
        FlushInQ(Com1);
     ComWrtByte (Com1,0x41 );    /*对应地址0x01*/
      for (i=0;i<10;i++)
         dataa='\0';
     Delay(0.5);  ///////////ren
        ComRd (Com1,dataa ,9 );
     for (i=0;i<10;i++)
         if((dataa!=0)&&(dataa!='0'))
             flag1=1;
             break;
         else
            flag1=0;
     if (flag1==0)
          for (i=0;i<10;i++)
             dataa='\0';
         for (i=0;i<10;i++)
                   flag1=1;
                   break;
             else
                flag1=0;
      }//if
     flag1=1;///////////////////////////////////////////////////////  ren
     if(flag1==0)
           //flag_THD_Start=0;
              SetCtrlVal (panelHandle, PANEL_TEXTMSG_TEMP, "请检查线路是否连接正常");
     SetCtrlAttribute (panelHandle, PANEL_TEXTMSG_TEMP, ATTR_TEXT_COLOR, VAL_RED);
     else
        SetCtrlVal (panelHandle, PANEL_TEXTMSG_TEMP, "温湿度测量正常");
     SetCtrlAttribute (panelHandle, PANEL_TEXTMSG_TEMP, ATTR_TEXT_COLOR, VAL_BLUE);
     if((dataa[3]&0x80)==0x00)
                    temp=(dataa[3]*256+dataa[4])/10.0;/*得到温度值*/
                else
                  temp=-1*((~dataa[3])*256+(~dataa[4]))/10.0;
              humd=(dataa[5]*256+dataa[6])/10.0;/*得到湿度值*/
              sprintf(tempe,"%5.2f",temp);
              strcat(tempe,"℃");
              SetCtrlAttribute(panelHandle,PANEL_TEMPERATURE,ATTR_VISIBLE,1);
      SetCtrlVal(panelHandle,PANEL_TEMPERATURE,tempe);
      sprintf(humid,"%5.2f",humd);
              strcat(humid,"% ");
               SetCtrlAttribute(panelHandle,PANEL_HUMIDITY,ATTR_VISIBLE,1);
      SetCtrlVal(panelHandle,PANEL_HUMIDITY,humid);
发表于 2011-5-13 10:41:37 | 显示全部楼层
你把你完整的程序打包传上来,咱们大家一起帮你看看吧!这样光看源码不好看的,另外附带上你的要求
 楼主| 发表于 2011-5-14 13:20:40 | 显示全部楼层
因为牵扯到硬件,没有硬件你只有帮我分析下代码问题!
GMT+8, 2026-9-28 07:04 , Processed in 0.023833 second(s), 6 queries , Gzip On, File On.
