查看: 843|回复: 3
在菜单使用loadpanel加载panel时的问题
y542114717 该用户已被删除
发表于 2011-5-26 10:48:43 | 显示全部楼层 |阅读模式
rt  在菜单使用loadpanel加载panel的时候 加载出来的panel 总是被另外一个panel挡住 如何使他显示在最上面啊? 或者是能不能改变下加载出来的panel 显示的位置  免得被挡住
发表于 2011-5-26 14:44:17 | 显示全部楼层
发表于 2011-5-26 14:46:54 | 显示全部楼层
没有程序只能猜测,你去试验一下这个labwindows的库函数。
int InstallPopup (int Panel_Handle);
发表于 2011-5-26 14:47:15 | 显示全部楼层
Displays and activates a panel as a modal dialog box.
You must call this function from the thread in which you create the panel.
While the modal dialog box is visible, the user cannot operate any other panels that you created in the same thread.
file:///d:/program%20files/national%20instruments/cvi85/bin/libref/note.gifNote  While you can pass a child panel to this function, it is not recommended. Although the panel will retain its status as a child panel, it will not behave like one while it is modal, which might produce unpredictable results elsewhere in your program.
file:///d:/program%20files/national%20instruments/cvi85/bin/libref/dot.gif Prototype file:///d:/program%20files/national%20instruments/cvi85/bin/libref/dot.gif
GMT+8, 2026-9-28 07:04 , Processed in 0.030306 second(s), 8 queries , Gzip On, File On.
