查看: 1840|回复: 0
crc16 keil c51
发表于 2004-11-6 03:23:43 | 显示全部楼层 |阅读模式
#pragma small
#include <reg52.h>
unsigned int CRC_16(unsigned int c,unsigned char d);
unsigned int    crc16=0;
void main(void)
//  unsigned char crcbuff[] = {31,3,0,1,0,7};
   unsigned char crcbuff[] = "123456789";
    unsigned char *p;
//  unsigned int crc16 = 0xffff;
    p=crcbuff;
while(*p !='\0')
        crc16 = CRC_16(crc16,*p++);
p=crcbuff;
    unsigned int data e;
    unsigned char data f;
    e = c^(unsigned int)d;
    for(f=0;f<8;f++)
        if(e&1)
            e >>= 1;
            e ^= 0xa001;
        else e >>= 1;
    return e;
// 使用字符串"123456789"测试,crc16初始值为0时
// 结果为0xbb3d 符合crc caculator
GMT+8, 2026-9-28 05:15 , Processed in 0.027728 second(s), 7 queries , Gzip On, File On.
