查看: 1844|回复: 1
[求助]谁来帮我看看怎么错了
发表于 2006-7-14 00:51:38 | 显示全部楼层 |阅读模式
int n;
             long filesize;
             double *data;
             char pathname[MAX_PATHNAME_LEN];
   switch (event)
    case EVENT_COMMIT:
     if (FileSelectPopup ("", "*.txt", "TXT Files", "文件名选择",VAL_LOAD_BUTTON, 1, 1, 1, 0, pathname));
       GetFileInfo(pathname,&filesize);
       n=sizeof(double);
       data=(double*)malloc(filesize);
       FileToArray(pathname,data,VAL_DOUBLE,filesize/n,1,VAL_GROUPS_TOGETHER,VAL_GROUPS_AS_ROWS,VAL_ASCII);
          PlotY(panelHandle,PANEL_3_GRAPH,data,filesize/n,VAL_DOUBLE,VAL_THIN_LINE,VAL_EMPTY_SQUARE,VAL_SOLID,1,VAL_RED);
    break;
以上程序,我先存了个4*7的数组在一个文本文件里面了.我要读出这个文件里面的数,然后画出图来.提示错误里面一直针对data这个数组的大小出问题.
发表于 2006-7-14 06:45:38 | 显示全部楼层
把程序压缩一下传上来给大家看看!呵呵!
GMT+8, 2026-9-28 20:15 , Processed in 0.031326 second(s), 7 queries , Gzip On, File On.
