查看: 3114|回复: 0
新手求助
l2014 该用户已被删除
发表于 2014-11-26 21:52:05 | 显示全部楼层 |阅读模式
菜鸟刚接触labview,用labview控制安捷伦的频谱分析仪,结果提示以下错误,请大神们给分析一下,感激不尽。The ID Query failed.  This may mean that you selected the wrong instrument or your instrument did not respond.  You may also be using a model that is not officially supported by this driver.  If you are sure that you have selected the correct instrument and it is responding, try disabling the ID Query.该肿么解决~~~
GMT+8, 2026-9-28 03:15 , Processed in 0.028714 second(s), 9 queries , Gzip On, File On.
