查看: 1376|回复: 0
Labwindows调用refprop出现20个错误,希望高手给以指点!
sodimi 该用户已被删除
发表于 2015-10-1 15:11:05 | 显示全部楼层 |阅读模式
如题,Labwindows调用refprop出现20个错误,跪等高手解困。{:soso_e199:}调用程序在附件中,错误如下:
Build Status (amlcvi.prj - Debug)
amlcvi.c - 20 errors
  25, 10    error: use of undeclared identifier 'AML_Initial'; did you mean 'AMLInitial'?
      22, 6    note: 'AMLInitial' declared here
  27, 16    error: unknown type name 'float64'; did you mean 'float'?
  30, 9    error: use of undeclared identifier 'Device_Error'
  30, 24    error: implicit declaration of function 'DAQmxCreateTask' is invalid in C99. Make sure that you include the function prototype.
  30, 44    error: use of undeclared identifier 'AI_task_handle'
  31, 13    error: use of undeclared identifier 'Device_Error'
  37, 9    error: use of undeclared identifier 'Device_Error'
  37, 24    error: implicit declaration of function 'DAQmxCreateAIVoltageChan' is invalid in C99. Make sure that you include the function prototype.
  37, 49    error: use of undeclared identifier 'AI_task_handle'
  38, 13    error: use of undeclared identifier 'Device_Error'
  44, 9    error: use of undeclared identifier 'Device_Error'
  44, 24    error: implicit declaration of function 'DAQmxStartTask' is invalid in C99. Make sure that you include the function prototype.
  44, 39    error: use of undeclared identifier 'AI_task_handle'
  45, 13    error: use of undeclared identifier 'Device_Error'
  52, 9    error: use of undeclared identifier 'Device_Error'
  52, 44    error: use of undeclared identifier 'AO_task_handle'
  53, 13    error: use of undeclared identifier 'Device_Error'
  59, 9    error: use of undeclared identifier 'Device_Error'
  59, 24    error: implicit declaration of function 'DAQmxCreateAOVoltageChan' is invalid in C99. Make sure that you include the function prototype.
  59, 49    error: use of undeclared identifier 'AO_task_handle'
Build failed.
GMT+8, 2026-9-28 06:32 , Processed in 0.037486 second(s), 14 queries , Gzip On, File On.
