查看: 1584|回复: 0
c51写的93C46的读写程序
发表于 2004-11-6 03:45:51 | 显示全部楼层 |阅读模式
//整理:聂小猛。该资料来自“51单片机世界”http://go.163.com/~dz2000,欢迎访问。
#include <reg52.h>
sbit CS=P2^7;
sbit SK=P2^6;
sbit DI=P2^5;
sbit DO=P2^4;
extern unsigned char ReadChar(unsigned char address);
extern void WriteChar(unsigned char address,unsigned char InData);
extern void ReadString(unsigned char data *RamAddress,unsigned char RomAddress,unsigned char Number);
extern void WriteString(unsigned char data *RamAddress,unsigned char RomAddress,unsigned char Number);
// Write enable must precede all programming modes.
void Ewen(void) {
        unsigned char temp,InData;
        CS=0;
        SK=0;
        CS=1;
        InData=0x98;        // 10011XXXX
        for(temp=9;temp!=0;temp--) {        // 9
                DI=InData&0x80;
                SK=1;        SK=0;
                InData<<=1;
        CS=0;
// Disables all programming instructions.
void Ewds(void) {
        CS=0;
        SK=0;
        CS=1;
        InData=0x80;        // 10000XXXX
                DI=InData&0x80;
                SK=1;        SK=0;
                InData<<=1;
        CS=0;
// Reads data stored in memory, at specified address.
unsigned int Read(unsigned char address) {
        unsigned char temp;
        unsigned int result;
        Ewen();
        SK=0;        DI=1;        // 110 A5-A0
        CS=0;        CS=1;
        SK=1;        SK=0;                        // 1
        address=address&0x3f|0x80;
        for(temp=8;temp!=0;temp--) {        // 8
                DI=address&0x80;
                SK=1;        SK=0;
                address<<=1;
        DO=1;
        for(temp=16;temp!=0;temp--) {        // 16
                SK=1;
                result=(result<<1)|DO;
                SK=0;
        CS=0;
        Ewds();
        return(result);
// Writes memory location An - A0.
void Write(unsigned char address,unsigned int InData) {
        unsigned char temp;
        Ewen();
        SK=0;        DI=1;        // 101 A5-A0
        CS=0;        CS=1;
        SK=1;        SK=0;                        // 1
        address=address&0x3f|0x40;
                DI=address&0x80;
                SK=1;        SK=0;
                address<<=1;
                DI=InData&0x8000;
                SK=1;        SK=0;
                InData<<=1;
        CS=0;        DO=1;
        CS=1;        SK=1;
        while(DO==0) {                        // busy test
                SK=0;        SK=1;
        SK=0;        CS=0;
        Ewds();
// Erase memory location An - A0.
void Erase(unsigned char address) {
        unsigned char temp;
        Ewen();
        SK=0;        DI=1;        // 111 A5-A0
        CS=0;        CS=1;
        SK=1;        SK=0;                        // 1
        address|=0xc0;
                DI=address&0x80;
                SK=1;        SK=0;
                address<<=1;
        CS=0;        DO=1;
        CS=1;        SK=1;
        while(DO==0) {
                SK=0;        SK=1;
        SK=0;        CS=0;
        Ewds();
// Erases all memory locations. Valid only at VCC = 4.5V to 5.5V.
void Eral(void) {
        Ewen();
        CS=0;
        SK=0;
        CS=1;
        InData=0x90;        // 10010XXXX
                DI=InData&0x80;
                SK=1;        SK=0;
                InData<<=1;
        CS=0;        DO=1;
        CS=1;        SK=1;
        while(DO==0) {
                SK=0;        SK=1;
        SK=0;        CS=0;
        Ewds();
// Writes all memory locations. Valid only at VCC = 4.5V to 5.5V.
void Wral(unsigned int InData) {
        unsigned char temp,address;
        Ewen();
        CS=0;
        SK=0;
        CS=1;
        address=0x88;        // 10001XXXX
                DI=address&0x80;
                SK=1;        SK=0;
                address<<=1;
                DI=InData&0x8000;
                SK=1;        SK=0;
                InData<<=1;
        CS=0;        DO=1;
        CS=1;        SK=1;
        while(DO==0) {
                SK=0;        SK=1;
        SK=0;        CS=0;
        Ewds();
unsigned char ReadChar(unsigned char address) {
        unsigned char temp=address>>1;
        if(address&0x01) return((unsigned char)(Read(temp)>>8));
        else return((unsigned char)(Read(temp)));
void WriteChar(unsigned char address,unsigned char InData) {
        if(address&0x01) Write(temp,(unsigned int)(Read(temp)&0x00ff|(InData<<8)));
        else Write(temp,(unsigned int)(Read(temp)&0xff00|InData));
void ReadString(unsigned char data *RamAddress,unsigned char RomAddress,unsigned char Number) {
        while(Number!=0) {
                *RamAddress=ReadChar(RomAddress);
                RamAddress++;
                RomAddress++;
                Number--;
void WriteString(unsigned char data *RamAddress,unsigned char RomAddress,unsigned char Number) {
        unsigned int temp;
        if(Number==0) return;
        if(RomAddress&0x01) {
                WriteChar(RomAddress,*RamAddress);
                RamAddress++;
                RomAddress++;
                Number--;
        while(Number>>1) {
                temp=*RamAddress;
                RamAddress++;
                temp=temp|(*RamAddress)<<8;
                RamAddress++;
                Write(RomAddress>>1,temp);
                RomAddress++;
                RomAddress++;
                Number--;
                Number--;
        if(Number) WriteChar(RomAddress,*RamAddress);
GMT+8, 2026-9-28 04:40 , Processed in 0.019238 second(s), 7 queries , Gzip On, File On.
