查看: 1439|回复: 0
c51写的X25045的读写程序
发表于 2004-11-6 03:46:30 | 显示全部楼层 |阅读模式
//整理:聂小猛。该资料来自“51单片机世界”http://go.163.com/~dz2000,欢迎访问。
   *  X25043/45 application ; Procedures
   *  absolute one address access
WARNING: The function with '_' ahead ,user may not use it.as it
used internal
//使用函数:write_status(status) 写状态,一般写0
//clr_wchdog(void)   清看门狗
//unsigned char        read_byte(address) //读一个字节
//void        write_byte(address,Data)   //写一个字节
#define        ALONE_COMPILE
#ifdef        ALONE_COMPILE
        #include "INTRINS.H"
#endif
#ifndef nop2()
#define nop2()  _nop_();_nop_();_nop_()
#endif
#define WREN    0x06
#define WRDI    0x04
#define RDSR    0x05
#define WRSR    0x01
#define READ    0x03
#define WRITE   0x02
//#define        PORT        P1
sfr        PORT=0x90; //25045的4根io脚接在同一端口,本例为p1
                        //请根据实际电路更改引脚定义
#define        _SI        0x80  //si接在p1.3,0x80=00001000b
#define        _SCK        0x40  //sck接在p1.2,0x80=00000100b
#define        _SO        0x20  //so接在p1.1
#define        _CS        0x10  //cs接在p1.0
#ifndef        dword
        #define        dword        unsigned long
        #define        word        unsigned int
        #define        byte        unsigned char
        typedef        union{
                word        w;
                byte        bh;
                byte        bl;
        }WordType;
        typedef        union{
                dword        dw;
                word        w[2];
                byte        b[4];
        }DwordType;
#endif
void        _w_byte(Data)
        char Data;
        char i;
        PORT &= (_SCK^0xff);
        for(i=0;i<8;i++)
                nop2();nop2();/////////////
                if(Data & 0x80)  PORT |= _SI;
                else PORT &= (_SI^0xff);
                PORT |=_SCK;
                Data=Data<<1;
char        _r_byte(void)
        char i;
        char result;
        result=0;
        for(i=0;i<8;i++)
                PORT |=_SCK;
                result=result<<1;
                if((PORT & _SO) != 0)
                        result |= 0x01;
                PORT &=(_SCK^0xff);
        return(result);
void        write_status(status)
        char status;
        PORT &=(_CS^0xff);
        _w_byte(status);
        PORT |=_CS;
        return;
void        clr_wchdog(void)
        PORT &= (_CS^0xff);
        PORT |=_CS;
void        wait_free(void)
        unsigned int  t;
        t=3000;
        while(--t);
void        write_reg(_code)
        char        _code;
        write_status(WREN);
        PORT &= (_CS^0xff);
        _w_byte(WRSR);
        _w_byte(_code);
        PORT |=_CS;
        wait_free();
        unsigned int        address;
        char        result;
        PORT &=(_CS^0xff);                // Chip select
        _w_byte((char)(address>255 ? (0x08|READ): READ));
        _w_byte((char)(address & 0x00ff));
        result=_r_byte();
        PORT |=_CS;
                                        // Chip unselect
        return(result);
        char Data;
        write_status(WREN);
        PORT &= (_CS^0xff);
        _w_byte((unsigned char)(address>255 ? (0x08|WRITE): WRITE));
        _w_byte((unsigned char)(address & 0x00ff));
        _w_byte(Data);
        PORT |=_CS;
        wait_free();
        return;
unsigned long        read_data(format,address)
        unsigned char        format;
        DwordType        result;
        switch(format&0xdf)
        case        'L':
                result.b[0]=read_byte(address);
                result.b[1]=read_byte(address+1);
                result.b[2]=read_byte(address+2);
                result.b[3]=read_byte(address+3);
                break;
        case        'D':
                result.b[2]=read_byte(address);
                result.b[3]=read_byte(address+1);
                break;
        case        'C':
                result.b[3]=read_byte(address);
                break;
        return(result.dw);
void        write_data(format,address,Data)
        DwordType data* Data;
        switch(format&0xdf)
        case        'L':
                write_byte(address  , Data->b[0]);
                write_byte(address+1, Data->b[1]);
                write_byte(address+2, Data->b[2]);
                write_byte(address+3, Data->b[3]);
                break;
        case        'D':
                write_byte(address  , Data->b[2]);
                write_byte(address+1, Data->b[3]);
                break;
        case        'C':
                write_byte(address  , Data->b[3]);
                break;
GMT+8, 2026-9-28 04:40 , Processed in 0.019943 second(s), 7 queries , Gzip On, File On.
