查看: 1650|回复: 0
c51写的24c02的读写程序
发表于 2004-11-6 03:47:26 | 显示全部楼层 |阅读模式
//整理:聂小猛。该资料来自“51单片机世界”http://go.163.com/~dz2000,欢迎访问。
#include <reg51.h>
// 对24C02的读、写
// extern void DelayMs(unsigned int);
// extern void Read24c02(unsigned char *RamAddress,unsigned char RomAddress,unsigned char bytes);
// extern void Write24c02(unsigned char *RamAddress,unsigned char RomAddress,unsigned char bytes);
#define        WriteDeviceAddress 0xa0
#define        ReadDviceAddress 0xa1
sbit        SCL=P1^4;
sbit        SDA=P1^3;
sbit        DOG=P3^7;
void DelayMs(unsigned int number) {
        unsigned char temp;
        for(;number!=0;number--,DOG=!DOG) {
                for(temp=112;temp!=0;temp--) {
void Start() {
        SDA=1;
        SCL=1;
        SDA=0;
        SCL=0;
void Stop() {
        SCL=0;
        SDA=0;
        SCL=1;
        SDA=1;
void Ack() {
        SDA=0;
        SCL=1;
        SCL=0;
        SDA=1;
void NoAck() {
        SDA=1;
        SCL=1;
        SCL=0;
bit TestAck() {
        bit ErrorBit;
        SDA=1;
        SCL=1;
        ErrorBit=SDA;
        SCL=0;
        return(ErrorBit);
bit Write8Bit(unsigned char input) {
        unsigned char temp;
        for(temp=8;temp!=0;temp--) {
                SDA=(bit)(input&0x80);
                SCL=1;
                SCL=0;
                input=input<<1;
void Write24c02(unsigned char *Wdata,unsigned char RomAddress,unsigned char number) {
        Start();
        Write8Bit(WriteDeviceAddress);
        TestAck();
        Write8Bit(RomAddress);
        TestAck();
        for(;number!=0;number--) {
                Write8Bit(*Wdata);
                TestAck();
                Wdata++;
        Stop();
        DelayMs(10);
unsigned char Read8Bit() {
        unsigned char temp,rbyte=0;
                SCL=1;
                rbyte=rbyte<<1;
                rbyte=rbyte|((unsigned char)(SDA));
                SCL=0;
        return(rbyte);
void Read24c02(unsigned char *RamAddress,unsigned char RomAddress,unsigned char bytes) {
        unsigned char temp,rbyte;
        Start();
        TestAck();
        TestAck();
        Start();
        Write8Bit(ReadDviceAddress);
        TestAck();
        while(bytes!=1) {
        *RamAddress=Read8Bit();
        Ack();
        RamAddress++;
        bytes--;
        NoAck();
        Stop();
GMT+8, 2026-9-28 04:40 , Processed in 0.019769 second(s), 7 queries , Gzip On, File On.
