查看: 3593|回复: 2
DM9000A配合默契的网络变压器YL18-2050S
发表于 2006-10-11 15:53:02 | 显示全部楼层 |阅读模式
DM9000A配合默契的网络变压器YL18-2050S,The DM9000A is a fully integrated and cost-effective low pin count single chip Fast controller with a general processor interface,a 10/100M PHY and 16K Byte SRAM. 网络变压器YL18-2050S特点:10/100 Base Single Port LAN Filters(SMD)-----Designed for 10/100 Base transmission over Cat 5 or better UTP Cable.16SMD package for economcal.Cable interface isolation and low common mode emissions.Meet all IEEE 802.3 standards including 350uH OCL with 8 mA DC Bias!
 楼主| 发表于 2006-10-11 16:01:54 | 显示全部楼层
<p><strong>不好意思!按照电路图网络变压器的型号为YL37-1107S,其功能与YL18-2050S一样.YL18-2050完全兼容H1102的DM9000A也可以配合使用,但PCB要改动一下!</strong></p>
h87711 该用户已被删除
发表于 2009-7-31 19:34:42 | 显示全部楼层
GMT+8, 2026-9-28 07:09 , Processed in 0.040591 second(s), 14 queries , Gzip On, File On.
