查看: 1427|回复: 0
asm写的cs5460程序
发表于 2004-11-6 03:54:10 | 显示全部楼层 |阅读模式
CLK     equ      P1.6;   --
DAT     equ      P1.7;   E2prom
dat7    equ      p0.3;   ---
clk7    equ      p0.2;   7289
cs7     equ      p0.1;
rset    equ      p0.0;   ---
sdi     equ      p1.5;   cs5460
sdo     equ      p1.4
sclk    equ      p1.3
csa     equ      p1.0
csb     equ      p1.1
csc     equ      p1.2;   ---
dog     equ      p3.5
REST:             ;5460复位
MOV     R6,#06H
MOV     R0,#0FFH
USA:
NOP
NOP
cpl     dog
ACALL   COMM
DJNZ    R6,USA    ;串行口初始化
MOV     R0,#0FEH
NOP
NOP
ACALL   COMM
MOV     10H,#00H
MOV     11H,#00H
MOV     12H,#81H
MOV     R0,#40H     ;CS5460复位
MOV     R1,#10H
NOP
NOP
ACALL   WWW
NOP
NOP
ACALL   T9
MOV      10H,#80H
MOV      11H,#00H
MOV      12H,#20H
MOV     R0,#74H
MOV     R1,#10H
NOP
NOP                  ;写中断寄存器
ACALL   WWW
NOP
NOP
ACALL   T9
MOV     10H,#00H
MOV     11H,#00H
MOV     12H,#71H
MOV     R0,#40H     ;写入5460配置寄存器
MOV     R1,#10H
NOP
NOP
ACALL   WWW
NOP
NOP
ACALL   T9
MOV     R0,#0D0H
NOP
NOP
LCALL   COMM        ;电压校准
ddd1:
MOV     R0,#1EH
MOV     R1,#10H
NOP
NOP
ACALL   READ
MOV     A,10H        ;等待校准完毕
JNB     ACC.7,ddd1
MOV     10H,#0FFH
MOV     11H,#0FFH
MOV     12H,#0FEH
MOV     R0,#5EH
MOV     R1,#10H
NOP
NOP
LCALL   WWW      ;清DRDY,WDT位
MOV     R0,#0C8H
NOP
NOP
LCALL   COMM           ;电流校准
Ddd2:
MOV     R0,#1EH
MOV     R1,#10H
NOP
nOP
ACALL   READ
MOV     A,10H           ;等待校准完毕
JNB     ACC.7,ddd2
MOV     10H,#0FFH
MOV     11H,#0FFH
MOV     12H,#0FEH
MOV     R0,#5EH
MOV     R1,#10H
NOP
NOP
NOP
NOP
LCALL    WUIROM     ;将校准值写入5460
NOP
NOP
ACALL    T9
;MOV     R0,#0C0H
;NOP
;NOP
;ACALL   COMM        ;禁止校准
MOV     10H,#0FFH
MOV     11H,#0FFH
MOV     12H,#0FEH
MOV     R0,#5EH
MOV     R1,#10H
NOP
NOP
NOP
NOP
ACALL    T9
MOV     R0,#0E8H
NOP
NOP
ACALL   COMM    ;进行连续计算
NOP
NOP
RET
T9:
MOV     R7,#0FFH
T2:
NOP
NOP
DJNZ    R7,T2
NOP
NOP
RET
COMM:   ;对芯片进行控制,命令字在R0
        clr     sdo
        MOV     A,R0
        MOV     R4,#08H
M1:     MOV     C,ACC.7
        MOV     sdi,C
        NOP
        NOP
        NOP
        NOP
        SETB     sclk
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        CLR     sclk
        NOP
        NOP
        NOP
        RL      A
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        DJNZ    R4,M1
        NOP
        NOP
        NOP
        RET
WWW:     ;命令字在R0,数据指针在R1,
        NOP
        NOP
        ACALL   COMM
        MOV     R6,#03H
  W1:   MOV     A,@R1
        MOV     R0,A
        NOP
        NOP
        ACALL   COMM
        INC     R1
        DJNZ    R6,W1
        NOP
        NOP
        RET
READ:   ;命令字在R0,数据指针在R1
        NOP
        NOP
        ACALL   COMM
        setb    sdi
        SETB    sdo
        MOV     R3,#08H
        MOV     R2,#03H
        NOP
        NOP
        NOP
        NOP
RR2:   CLR    sclk
        CLR     C
        CLR     A
RR1:   NOP
        NOP
        NOP
        NOP
        SETB    sclk
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        MOV     C,sdo
        MOV     ACC.7,C
        RL        A
        NOP
        CLR     sclk
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
     ;读数时最后一个脉冲,Sdi为低电平
        cjne   r2,#01h,readjie
        cjne   r3,#02h,readjie
        clr    sdi
readjieJNZ   R3,RR1
        MOV    R3,#08H
        MOV    @R1,A
        INC    R1
        DJNZ   R2,RR2
        clr    sdi
        NOP
        NOP
        NOP
        RET
GMT+8, 2026-9-28 04:40 , Processed in 0.018903 second(s), 7 queries , Gzip On, File On.
