查看: 1118|回复: 4
请教:调用dll的问题
发表于 2006-11-20 09:07:33 | 显示全部楼层 |阅读模式
我用VC封装了一个win32dll,用于停用和启用设备.
用LABVIEW调用的时候,停用设备时,labVIEW程序出现暂时的未响应;而在启用设备时则正常.
不知道为什么?请高手指点一下
发表于 2006-11-20 09:28:11 | 显示全部楼层
最好能把DLL文件及头文件放上来,大家好看一下,你这样讲大家没什么头绪的,
 楼主| 发表于 2006-11-20 09:51:04 | 显示全部楼层
#include "stdio.h"
#include "windows.h"
#include "rpcdce.h"
#include <setupapi.h>
#include <shlwapi.h>
#include "tchar.h"
//#include "stdlib.h"
//#include "Winbase.h"
#pragma comment(lib, "rpcrt4.lib")
#pragma comment(lib, "setupapi.lib")
#pragma comment(lib, "shlwapi.lib")
HDEVINFO hDevInfo = NULL;
void FormatMSG(DWORD dwError, LPTSTR * lpszMsg)
   BOOL bOk = FormatMessage(FORMAT_MESSAGE_FROM_SYSTEM | FORMAT_MESSAGE_ALLOCATE_BUFFER, NULL, dwError,
   MAKELANGID(LANG_CHINESE, SUBLANG_CHINESE_SIMPLIFIED), (LPTSTR)lpszMsg, 0, NULL);
   if(!bOk)
           HMODULE hDll = LoadLibraryEx(("netmsg.dll"),
                   NULL,
                   DONT_RESOLVE_DLL_REFERENCES);
        if (NULL != hDll)
                FormatMessage(FORMAT_MESSAGE_FROM_HMODULE |
                        FORMAT_MESSAGE_FROM_SYSTEM,
                        hDll,
                        dwError,
                        (LPTSTR)lpszMsg,0, NULL);
                FreeLibrary(hDll);
BOOL ChangeStatus(DWORD NewStatus, DWORD SelectedItem, HDEVINFO hDevInfo)
        LPTSTR lpszMsg = NULL;
        HCURSOR hCursor = NULL;
        try
                SP_PROPCHANGE_PARAMS PropChangeParams = {sizeof(SP_CLASSINSTALL_HEADER)};
                SP_DEVINFO_DATA DeviceInfoData = {sizeof(SP_DEVINFO_DATA)};
                hCursor = SetCursor(LoadCursor(NULL, IDC_WAIT));
                if (!SetupDiEnumDeviceInfo(hDevInfo, SelectedItem, &DeviceInfoData))
                        FormatMSG(GetLastError(), &lpszMsg);
                        throw lpszMsg;
        // Set the PropChangeParams structure.
                PropChangeParams.ClassInstallHeader.InstallFunction = DIF_PROPERTYCHANGE;
                PropChangeParams.Scope = DICS_FLAG_GLOBAL;
                PropChangeParams.StateChange = NewStatus;
                if (!SetupDiSetClassInstallParams(hDevInfo, &DeviceInfoData, (SP_CLASSINSTALL_HEADER *)&PropChangeParams,
                        sizeof(PropChangeParams)))
                        throw lpszMsg;
                // Call the ClassInstaller and perform the change.
                if (!SetupDiCallClassInstaller(DIF_PROPERTYCHANGE,hDevInfo,&DeviceInfoData))
                        throw lpszMsg;
                SetCursor(hCursor);
                return TRUE;
        catch (TCHAR * pszError)
                SetCursor(hCursor);
        //        ::MessageBox(NULL,pszError,"提示",MB_OK);
                if (NULL != lpszMsg)
                        LocalFree((HLOCAL)lpszMsg);
                return FALSE;
_declspec(dllexport) BOOL ControlDisk(int nStatus, int nIndex)
        if (-1 == nStatus)
                return FALSE;
        try
                TCHAR * GUIDString = NULL;
                GUID guid;
                ZeroMemory(&guid, sizeof(GUID));
                switch(nIndex)
                case 0:
                        GUIDString = _T("4D36E980-E325-11CE-BFC1-08002BE10318");
                        UuidFromString((unsigned char *)GUIDString, &guid);
                        break;
                case 1: // 1 代表光驱
                        GUIDString = _T("4D36E965-E325-11CE-BFC1-08002BE10318");
                        break;
                case 2: // 2 代表USB 36FC9E60-C465-11CF-8056-444553540000
                        GUIDString = _T("71A27CDD-812A-11D0-BEC7-08002BE2092F");
                        break;
                hDevInfo = SetupDiGetClassDevs(&guid,NULL,NULL,DIGCF_PRESENT);
                if (INVALID_HANDLE_VALUE == hDevInfo)
                        throw lpszMsg;
                DWORD i;
                SP_DEVINFO_DATA DeviceInfoData;
                ZeroMemory(&DeviceInfoData, sizeof(SP_DEVINFO_DATA));
                DeviceInfoData.cbSize = sizeof(SP_DEVINFO_DATA);
                for (i = 0; SetupDiEnumDeviceInfo(hDevInfo, i, &DeviceInfoData); ++i)
                        if (1 == nStatus)
                                ChangeStatus(DICS_ENABLE, i, hDevInfo);
                        else if (0 == nStatus)
                                ChangeStatus(DICS_DISABLE, i, hDevInfo);
                return SetupDiDestroyDeviceInfoList(hDevInfo);
                //::MessageBox(NULL,pszError,_T("提示"),MB_OK);
                return FALSE;
        return FALSE;
以上就是dll程序了(没做头文件,不知道需要否????).labview调用ControlDisk函数.
当输入参数0,2时;卸载usb设备,labview程序就会暂时的未响应.
当输入参数1,2时;启用usb设备,labview程序正常.
请高手指点一下,谢谢
发表于 2006-11-20 13:12:05 | 显示全部楼层
没什么问题呀~~~~~~~
停用时会有一个等侍响应,应是这样吧~~~~~
发表于 2006-11-20 21:17:17 | 显示全部楼层
如果在DLL里面有延时的话它就会有一个无法响应的时间的!
GMT+8, 2026-9-29 17:39 , Processed in 0.030699 second(s), 8 queries , Gzip On, File On.
