查看: 3606|回复: 2
lw如何合并字符串?
发表于 2006-12-18 10:37:12 | 显示全部楼层 |阅读模式
如题。比如
#define A="123"
int        b=4;
char      strB;
Fmt(strB, %s<%i, b);
合并A和strB,把strB加入到A的后面。
发表于 2006-12-18 21:11:20 | 显示全部楼层
用这个函数可以:
This function appends a copy of a source string (including the terminating ASCII NUL byte) to the end of a target string.  The initial character of the string to append overwrites the NUL byte at the end of the target string.  If copying takes place between objects that overlap, the behavior is undefined.
/*-------------------- Prototype ---------------------*/
char *strcat (char Target_String[],
              const char String_to_Append[]);
发表于 2007-2-4 03:41:35 | 显示全部楼层
这个应该是c的函数吧~~~直接用就行了
GMT+8, 2026-9-28 15:25 , Processed in 0.030763 second(s), 6 queries , Gzip On, File On.
