查看: 2234|回复: 2
求助DAQ-mx安装问题
发表于 2006-12-25 15:59:50 | 显示全部楼层 |阅读模式
安装了两天了,还是没安装上,从来没遇见过这种问题的
安装过程中出现了注册表错误,如图,我快疯了
发表于 2006-12-25 17:44:44 | 显示全部楼层
daq是正版的了?
下面是ni的help:
  • Write down the path to the key referred to in the error.
  • Choose Start » Run, and type regedit in the text field to open the Windows Registry editor.
  • Before editing the registry, you should first backup your current registry file:In the Registry Editor dialog box select File » Export.
  • Select All for the Export Range and save the file to a location of your choice.
  • Right-click on the parent of the key referred to in the error message and select Permissions from the shortcut menu. In this example the key is HKEY_LOCAL_MACHINE\Software\Classes\LVDB.Application.
  • (Note: Windows XP does not seem to save the registry setting in this step. In this case, the next step solves the problem.) In the Permissions dialog box, click on the Advanced button and select both Inherit from parent the permission entries that apply to child objects. Include these with entries explicitly defined here. and Replace permission entries on all child objects with entries shown here that apply to child objects, and click OK and Yes to continue.
  • Close the permissions box for the parent key and open up the permissions box for the key specific to the error by right-clicking on the key and selecting Permissions. Verify that the group SYSTEM is populated in the group or user name list. Also click on this group and verify that it has full permissions. If the group exists with full persmissions, you should now be able to install LabVIEW.
  • If the group exists but does not have full permissions, click on the Advanced button. Then select SYSTEM and click Edit. Then check the box to allow full control and click OK. You should now be able to install LabVIEW.
  • If the group SYSTEM does not exist, you can manually add the group. Click on the Advanced button and then click on the Add button. Type SYSTEM in the object name field and click OK. Then check the checkbox to allow full control and click OK. You should now be able to install LabVIEW.
      大概的意思就是你当前用户的权限不够,可以在注册表编辑器中修改
[ 本帖最后由 飞雨天 于 2006-12-25 17:51 编辑 ]
发表于 2007-1-23 22:35:04 | 显示全部楼层
DAQ和DAQ-mx是不能同时安装在一台机器上的.
查查,是不是这个原因.应该没有什么正版和盗版问题.那个软件包本来就是免费的嘛.
GMT+8, 2026-9-29 21:14 , Processed in 0.040804 second(s), 13 queries , Gzip On, File On.
