查看: 1882|回复: 1
Basic Level Trigger Detection函数用法帮助
发表于 2007-2-10 17:01:17 | 显示全部楼层 |阅读模式
大家好,请问波形检测中的Basic Level Trigger Detection函数怎么用,其中的hysteresis 节点是什么意思啊,看了帮助不是很明白。帮助如下,请高手指点
hysteresis specifies the amount above and below level through which each signal contained in signal in must pass before a trigger level crossing is detected. Trigger hysteresis is used to prevent noise from causing a false trigger. For a rising edge slope, the signal must pass below level – hysteresis before a trigger level crossing is detected. For a falling edge slope, the signal must pass above level + hysteresis before a trigger level crossing is detected.
发表于 2007-2-11 11:04:30 | 显示全部楼层
这个是检测信号触发的,Level是你开始CHECK的标准幅值,
hysteresis是滞后多少,
LV中有个例子,你可以看下
GMT+8, 2026-9-30 00:56 , Processed in 0.021481 second(s), 8 queries , Gzip On, File On.
