查看: 4387|回复: 11
NI 服务定位器未运行
发表于 2007-3-2 10:23:55 | 显示全部楼层 |阅读模式
我在使用labview查找范例时,出现“NI 服务定位器未运行”的对话框。而后,不能够打开范例,不知到怎么才能是其运行?
谢谢!
发表于 2007-3-2 13:26:48 | 显示全部楼层
精华列表贴中有收录这个的,要把这个东东给启动一下,是在NI上面找到的这个办法,您试试!您在精华列表贴里面找找,有的,我收录过的!好运兄弟!
发表于 2007-3-2 14:41:21 | 显示全部楼层
偶碰到过的是,这个服务跟本就启动不了,装的有问题,不知你的是什 么情况
发表于 2007-3-5 08:47:23 | 显示全部楼层
我其实和lgh269兄是一样的问题,把所有的服务都启动了还是有问题,可能是没有安装的问题,家里的电脑又不会有这个问题,搞不清。
iulee 该用户已被删除
发表于 2007-4-10 21:53:46 | 显示全部楼层
我也遇到这个问题,看了精华帖的办法解决,多半应该是防火墙的问题
69,为什么要要搜索LV的例子的时候,它提示服务没有打开,Error: NI Service Locator is Not Running?
Problem: When I try to open the NI Example Finder, I get the following error: "NI Service Locator is not running." How can I fix this error?
Solution: The NI Service Locator is a service that runs in the background of the operating system. This service enables the proper execution of several features including the LabVIEW Example Finder and some help options in LabVIEW. If this service is not running or is not running correctly, some of these features will not execute correctly. A simple thing to try is to restart the service. You can do this by opening up the Windows Services window by going to Start » Control Panel » Administrative Tools » Services. In the list of services you should see: NI Service Locator. To restart this service, right-click on the entry and select Stop. Wait a minute until the service has stopped and then right-click and select Start. Restart LabVIEW and see if you still get this error.
If you follow these steps, and you still cannot open the NI Example Finder, make sure that any personal firewall software, such as Norton Internet Security or ZoneLabs ZoneAlarm, has given server permissions to the NI Service Locator. If you still get this error contact National Instruments Technical Support.
发表于 2007-4-10 22:12:10 | 显示全部楼层
哈哈,这个问题我是久经折磨啊,就是防火墙把服务禁用了造成的!在防火墙规则里面找找,把和ni相关的都允许,就ok了!这个和安装没关系。
发表于 2007-4-11 09:08:56 | 显示全部楼层
check this item
 楼主| 发表于 2007-4-27 09:58:06 | 显示全部楼层
呵呵,问题终于解决了,谢谢
发表于 2007-5-13 13:56:08 | 显示全部楼层
我装的是8.2 20周年版 的 把服务全都启用了 防火墙禁用了 都不行。有没有不是防火墙问题的解决办法啊?
发表于 2007-5-13 15:48:29 | 显示全部楼层
那你在服务里面查看是否有locator 的服务程序,如果没有专门修复下这个程序,就是重新安装下定位器。
dxk4377361 该用户已被删除
发表于 2011-3-23 23:21:08 | 显示全部楼层
回复 lgh269 的帖子
然后您是怎么启动的呢,我的也是在“服务”这一项里面根本就不能启动,不知道是怎么回事??如果您能给解决的话将不胜感激
yangmeijun 该用户已被删除
发表于 2011-6-13 15:45:59 | 显示全部楼层
非常感谢5#的解答,以及能够查看了,谢谢
GMT+8, 2026-9-28 11:29 , Processed in 0.068096 second(s), 15 queries , Gzip On, File On.
