查看: 1365|回复: 2
labview8.2安装仪器驱动找不到Solution Wizards向导啊!
发表于 2007-3-12 15:50:50 | 显示全部楼层 |阅读模式
我使用的是labview8.2 20周年版本,安装了agilent仪器的驱动后readme提示要打开labview然后选择Solution Wizards,这个我找了半天也没找到不知在哪里啊!不知道大家有没有见过?
Function Panel Conversion
After installing the HP 816x VXIplug&play Instrument Driver, the driver has to be converted for use with LabView.
To convert the driver follow these steps:
Locate the LabView program folder. By default, this is <drive>rogram Files\National Instruments\LabView.
This folder contains a subfolder named instr.lib.
This subfolder contains a directory named hp816x. Delete this directory.
Run LabView.
On the first window that appears, click on the Solution Wizards button.
The LabView Solution Wizard window appears, click on the Launch Wizard… button.
The Welcome to Instrument Wizard! window appears, click on the Next > button.
The Search for Instruments… window appears, click on the Next > button. Check that the options are the same as displayed in the figure below:
[ 本帖最后由 zx1221 于 2007-3-12 15:59 编辑 ]
发表于 2007-3-12 16:47:06 | 显示全部楼层
装好GPIB驱动在NI的菜单中就会看到
 楼主| 发表于 2007-3-13 14:14:53 | 显示全部楼层
驱动是装好了,但是怎么找也找不到这个Solution Wizards
[ 本帖最后由 zx1221 于 2007-3-13 14:23 编辑 ]
GMT+8, 2026-9-30 01:33 , Processed in 0.051856 second(s), 13 queries , Gzip On, File On.
