查看: 1844|回复: 16
老师留的作业 实在是看不懂啊 大哥大姐帮帮忙吧
发表于 2007-5-9 16:07:49 | 显示全部楼层 |阅读模式
Lesson 1 Introduction to LabVIEW
1.    What are the two main windows in the LabVIEW environment?
2.    How many parts does each VI contain? What are they?
3.    What are the differences between controls and functions? Where are each located?
4.    What are the three palettes in the LabVIEW environment?
5.    How do you get help?
Lesson 2 Modular Programming
1.    A VI used as a subVI must have what two parts?
2.    How do you load a subVI into a LabVIEW diagram?
3.    How can you modularize the program in your diagram?
Lesson 3 Repetition and Loops
1.    What structure must ALWAYS run at least once?
2.    How can you control the speed at which the loop executes?
3.    Why would you want to use a shift register?
4.    How do you retain multiple values from previous iterations?
Lesson 4 Arrays
1.    What is an array? Where might it be used?
2.    How would you create a 2D array of numeric controls?
3.    How can a loop create an array? Which loops can be used to do so?
4.    What does “polymorphic” mean?
Lesson 5 Clusters
1.    What is the difference between an array and a cluster?
2.    What items are contained in the error cluster?
Lesson 6 Plotting Data
1.    What are the three update modes for a chart?
2.    What is the different between a chart, graph and XY graph?
Lesson 7 Making Decisions in a VI
1.    How can you make a decision in a VI?
2.    How do you use a case structure?
3.    When would it be best to use a formula node?
Lesson 8 Strings and File I/O
1.    What are some uses of strings?
2.    In what ways can you write to a spreadsheet file?
Lesson 9 Data Acquisition and Waveforms
1.    How are DAQ Boards configured?
2.    How can you test the configuration of your board?
Lesson 11 VI Customization
1.    What is the difference between VI Setup and SubVI Node Setup?
2.    How do you make a subVI open its front panel when it is run?
3.    Why should you use the Save with Options before modifying your VI Setup options?
4.    How can you edit a VI that opens, runs, and closes or is locked?
5.    In what ways can you customize the Controls and Functions palettes?
明天就必须交了 中文或者英文的回答都行,不胜感激!!!
发表于 2007-5-9 16:38:43 | 显示全部楼层
问题都非常简单,没有什么难的.你就自己挨个做吧.
 楼主| 发表于 2007-5-9 17:28:32 | 显示全部楼层
要帮忙就帮,不帮就算了!
要帮忙就帮,不帮就算了!你是会所以你觉得简单,简直是废话!!!我要是觉得简单还来求助么?版主,不是北京的吧,不是我瞧不起你们,北京孩子是该聊的时候聊,别人有困难的时候不会袖手旁观,更不会说风凉话的。再多学学怎么做人在出来混吧,素质教育就是针对你们制定的,还不好好学!这不是浪费国家资源是什么?就你这货判你个十年八年的都是轻的!
 楼主| 发表于 2007-5-9 17:31:55 | 显示全部楼层
你的一切留言代表了网站,我会一字不差的转发到各个论坛,供大家参考
你的一切留言代表了网站,我会一字不差的转发到各个论坛,供大家参考,对你也是一种激励吧,不用太感谢我了!
发表于 2007-5-9 18:07:22 | 显示全部楼层
wdyjz斑竹的热情大家有目共睹,再说了,你的东西本来就很简单,随便买本labview的教材看2天就能做了,我们不回答这类的问题是为了你好。最后,引用一句以前一个前辈的话,论坛论坛,是讨论的地方,别进行人身攻击。。。。。
PS:发现一个很伤心的现象,现在的问题越来越。。。。我好几次都没心情来了。。。毕竟我们来论坛也是为了提高。。。
发表于 2007-5-9 20:25:19 | 显示全部楼层
也是,支持飞雨天 的言语,不可能什么都在论坛上求的哟。
发表于 2007-5-9 21:45:58 | 显示全部楼层
首先你的出言就本身体现了你素质高低.
而且WDYJZ兄对论坛的贡献对于经常来论坛的人大家应该都知道.
从另外一个方面的说,本身你提的问题是LV的基础知识,你们老师有教你们这个课程的话,如果你有听得话哪怕不是非常认真我觉得这些问题对于你来说也起码懂一些.而你把所有的问题都提出来说明你根本没有自己付出的一些努力和求知的欲望,纵观来看你根本只是为了应付老师.
建议你自己多看看书,不只要看书,而且要消化书的知识,从而从书中学会做人的道理.
希望你能够接受建议.
发表于 2007-5-9 23:53:04 | 显示全部楼层
就这个孩子,还谈素质教育啊,
真让人感觉惊险。
无语了,CUPUBBS,用你的删除用户的功能吧。
发表于 2007-5-10 11:00:30 | 显示全部楼层
支持wdyjz.其实有些事情要自己去探索,那样所得的比直接问人要多得多.
 楼主| 发表于 2007-5-10 11:04:12 | 显示全部楼层
一帮xxx!!!无语!!!
以8楼“高杰”为首,除了5楼6楼的,就你们这号的,我都懒得骂你们,继续追随你们的斑竹,凑合活着吧
发表于 2007-5-10 12:49:08 | 显示全部楼层
471only
把你的教材稍微看看就OK了。
没人有功夫和你对骂什么的。
我大概看了你的问题,看完大部分参考书的前3-4章,基本搞定。后面的几个问题往后翻翻就行了。
没有人有必须回答你问题的义务。
既然是学习,就要虚心。
发表于 2007-5-10 17:42:14 | 显示全部楼层
怎么北京有这样的人
应该踢出去
发表于 2007-5-10 17:43:23 | 显示全部楼层
这种懒惰之人,估计也不会有多大。。。。。。
发表于 2007-5-13 18:49:04 | 显示全部楼层
“素质教育就是针对你们制定的,还不好好学!”既然这么说,那就是你学得好了?学的好还问?盐吃多了闲的?
我北京朋友,没有一个你这么样的。你丢首都人民的脸啊!
英语都看不懂,就不要搞虚拟仪器了。
斑竹不是义务给你回答问题的人。只能怪你平时不用功。出了事情,先把他人骂一通,不知道你爸妈怎么教育你的
这么一大堆,第一个1.    What are the two main windows in the LabVIEW environment?
这个问题也拿上来问?都不觉得丢人么!
等你工作了,必然被炒鱿鱼。我期待着呢。到时候,就是骂天骂地都没用。
没人可怜你!!
[ 本帖最后由 satage 于 2007-5-13 18:54 编辑 ]
发表于 2007-5-13 19:50:59 | 显示全部楼层
呵呵。
这孩子也怪可怜的,
楼上的随便说说就算了吧。呵呵。
GMT+8, 2026-9-30 08:18 , Processed in 0.061547 second(s), 7 queries , Gzip On, File On.
