查看: 616|回复: 1
运行LV放生的问题
发表于 2007-5-9 20:52:14 | 显示全部楼层 |阅读模式
我的电脑上装了LV声音震动工具包,以前可以用,不知道为什么现在每打开里面任何的例子VI都出现这个错误,哪位高手帮忙诊断下是什么问题,给想个办法,感激大了!!!
Error 1445 occurred at Open VI Reference in svx_Set Panel Size.vi->SVXMPL_Multichannel FFT (simulated).vi
Possible reason(s):
LabVIEW:  Open VI Reference will no longer match VIs in memory by file name. A VIs full name now includes any owning libraries so a filename is no longer sufficient. You can use strip path to wire the filename as a string, but this will not work for VIs in libraries.
VI Path: D:\LabVIEW Product\LabVIEW 8.0\examples\Sound and Vibration\Utility\Cosmetic\SVXMPL_Multichannel FFT (simulated).vi
发表于 2007-5-9 21:51:30 | 显示全部楼层
我以前也出现过这种问题,不过后来重装后就没有了。我现在也没怎么明白。
GMT+8, 2026-9-30 06:52 , Processed in 0.021198 second(s), 8 queries , Gzip On, File On.
