查看: 1757|回复: 10
求助!急!谢谢
发表于 2007-5-10 20:18:47 | 显示全部楼层 |阅读模式
我现在在用LabWindow做一个虚拟设备,结果遇到了很多问题。
我要做的是对信号的检测虚拟软件,现在已经把虚拟信号调试完了,但是面板之间转换按键却转换不了,老是有问题!再就是虚拟出来的信号要在检测面板用7个灯来显示的检测结果,如果检测过程中在某个地方有信号不符合要求的话,相应的灯就会熄灭,然后检测停止,接下来的灯也就是熄灭的。可是我总是想不通,编不出来!麻烦各位高手了,帮小弟费心了!最好有程序给我研究下!在这里先谢谢拉!
发表于 2007-5-12 14:22:50 | 显示全部楼层
你最好能把代码贴出来看看,这样说,不太清楚你的目的。
sha98_0 该用户已被删除
发表于 2007-5-13 08:41:51 | 显示全部楼层
达到
哈哈老栾的帖子呵呵合乎
 楼主| 发表于 2007-5-14 07:45:33 | 显示全部楼层
struct CHANNELDATA{
        int waveform;
        double frequency;
        double scope;
        int pointnum;
        double data[MAX_POINTS];
        }Channel1,Channel2;
static int handle;
static int panelHandle;
static int panelhandle2;
int channel=0,channel_signal=0;
double channel_scope_gain=1.0,channel_frequency_gain=1;
int chartmode=1;//continue
int power=0;//off
//static int waveform=1;//sine
static double data[MAX_POINTS*2];
void GenerateData(void)  ;
int main (int argc, char *argv[])
        if (InitCVIRTE (0, argv, 0) == 0)        /* Needed if linking in external compiler; harmless otherwise */
                return -1;        /* out of memory */
        if ((panelHandle = LoadPanel (0, "检测设备.uir", PANEL)) < 0)
                return -1;
        DisplayPanel (panelHandle);
        Channel1.frequency=1.0;
        Channel1.scope=1.0;
        Channel1.pointnum=512;
        Channel1.waveform=1;//sin
        Channel2.frequency=1.0;
        Channel2.scope=1.0;
        Channel2.pointnum=512;
        Channel2.waveform=1;//sin
        RunUserInterface ();
        DiscardPanel(panelHandle);
        return 0;
int CVICALLBACK DataFunc (int panel, int control, int event,
double signal_scope,signal_frequency;
int waveform;
    switch (control)
        case PANEL_SCOPEGAIN:
            if (event == EVENT_VAL_CHANGED)
                 GetCtrlVal (handle, PANEL_SCOPEGAIN, &channel_scope_gain);
            break;
        case PANEL_FREQGAIN:
                 GetCtrlVal (handle, PANEL_FREQGAIN, &channel_frequency_gain);
            break;
        case PANEL_SCOPE:
                if (event == EVENT_COMMIT)
        GetCtrlVal (handle, PANEL_SCOPE, &signal_scope);
        if(channel_signal==0)
                Channel1.scope=signal_scope;
        else
        Channel2.scope=signal_scope;
                break;
        case PANEL_FREQUENCY:
        GetCtrlVal (handle, PANEL_FREQUENCY, &signal_frequency);
        Channel1.frequency=signal_frequency;
        else
        Channel2.frequency=signal_frequency;
                break;
        case PANEL_WAVEFORM:
                    GetCtrlVal (handle, PANEL_WAVEFORM, &waveform);
        Channel1.waveform=waveform;
        else
        Channel2.waveform=waveform;
            break;
    return (0);
int CVICALLBACK ChartMode (int panel, int control, int event,
int Mode;
switch (event)
        case EVENT_COMMIT:
        GetCtrlVal (handle, PANEL_CHART_MODE, &chartmode);
        switch(chartmode)
        case 0: Mode=VAL_SWEEP;
        break;
        case 1: Mode= VAL_CONTINUOUS;
        break;
        case 2: Mode= VAL_BLOCK;
        break;
        SetCtrlAttribute (handle, PANEL_CHART, ATTR_SCROLL_MODE, Mode);
        break;}
        return 0;
int CVICALLBACK Quit (int panel, int control, int event,
switch (event)
        case EVENT_COMMIT:
        QuitUserInterface (0);
        break;
        return 0;
int CVICALLBACK SelectChannel (int panel, int control, int event,
switch (event)
        case EVENT_COMMIT:
        GetCtrlVal (handle, PANEL_CHANNEL, &channel);
        break;
        return 0;
int CVICALLBACK Timer (int panel, int control, int event,
int i;
switch (event)
        case EVENT_TIMER_TICK:
        GenerateData();
        if(channel==0)
        PlotStripChart (handle, PANEL_CHART, Channel1.data, Channel1.pointnum, 0, 0, VAL_DOUBLE);
        if(channel==1)
        PlotStripChart (handle, PANEL_CHART, Channel2.data, Channel2.pointnum, 0, 0, VAL_DOUBLE);
        if(channel==2)
        PlotStripChart (handle, PANEL_CHART, data, Channel1.pointnum*2, 0, 0, VAL_DOUBLE);
        break;
        return 0;
int CVICALLBACK Power (int panel, int control, int event,
switch (event)
        case EVENT_COMMIT:
        GetCtrlVal (handle, PANEL_POWER, &power);
        SetCtrlVal (handle, PANEL_LED, power);
        SetCtrlAttribute (handle, PANEL_TIMER, ATTR_ENABLED, power);
        if(power==0)
        ClearStripChart (handle, PANEL_CHART);
        break;
        return 0;
int CVICALLBACK ChannelSignal (int panel, int control, int event,
switch (event)
        case EVENT_COMMIT:
        GetCtrlVal (handle, PANEL_CHANNELSIGNAL, &channel_signal);
             SetCtrlVal (handle, PANEL_FREQUENCY, Channel1.frequency);
             SetCtrlVal (handle, PANEL_SCOPE, Channel1.scope);
             SetCtrlVal(handle,PANEL_WAVEFORM,Channel1.waveform) ;
        else
        SetCtrlVal (handle, PANEL_FREQUENCY, Channel2.frequency);
        SetCtrlVal (handle, PANEL_SCOPE, Channel2.scope);
        SetCtrlVal(handle,PANEL_WAVEFORM,Channel2.waveform);
        break;
        return 0;
int CVICALLBACK Channel (int panel, int control, int event,
        switch (event)
        case EVENT_COMMIT:
        if(channel==0)
                SetCtrlAttribute (handle, PANEL_CHART, ATTR_NUM_TRACES, 1);
                SetTraceAttribute (handle,PANEL_CHART,1 ,ATTR_TRACE_COLOR, VAL_GREEN);
                if(channel==1)
                        SetTraceAttribute (handle, PANEL_CHART,1, ATTR_TRACE_COLOR, VAL_RED);
                        }                                                          if(channel==2)
                        SetCtrlAttribute (handle, PANEL_CHART, ATTR_NUM_TRACES, 2);
                        SetTraceAttribute (handle, PANEL_CHART,1,ATTR_TRACE_COLOR, VAL_GREEN);
                        SetTraceAttribute (handle, PANEL_CHART,2,ATTR_TRACE_COLOR, VAL_RED);
                        break;
        return 0;
void CalculatePointNum()
        if(channel==0)
        Channel1.pointnum=1024/Channel1.frequency/channel_frequency_gain ;
        else if(channel==1)
        Channel2.pointnum=1024/Channel2.frequency/channel_frequency_gain ;
        else
        {   //SET SAME POINT
        Channel2.pointnum=1024/Channel1.frequency/channel_frequency_gain ;
void GenerateData()
        int i;
        CalculatePointNum();
        switch (Channel1.waveform)
        case 0:
                for (i=0; i<Channel1.pointnum/2; i++)
                     Channel1.data =Channel1.scope/channel_scope_gain ;
                for (i=Channel1.pointnum/2; i<Channel1.pointnum; i++)
                     Channel1.data =-Channel1.scope/channel_scope_gain ;
            break;
        case 1:
                for (i=0; i<Channel1.pointnum; i++)
                     Channel1.data = sin (i*2.0*PI/Channel1.pointnum) * Channel1.scope/channel_scope_gain ;
            break;
        case 2:
                Channel1.data = ((rand()/23767.0) - 0.5) * Channel1.scope/channel_scope_gain ;
            break;
        switch (Channel2.waveform)
        case 0:
                for (i=0; i<Channel2.pointnum/2; i++)
                     Channel2.data =Channel2.scope/channel_scope_gain ;
                for (i=Channel2.pointnum/2; i<Channel2.pointnum; i++)
                     Channel2.data =-Channel2.scope/channel_scope_gain ;
            break;
        case 1:
            for (i=0; i<Channel2.pointnum; i++)
                 Channel2.data = sin (i*2.0*PI/Channel2.pointnum) * Channel2.scope/channel_scope_gain ;
            break;
        case 2:
                Channel2.data = ((rand()/23767.0) - 0.5) * Channel2.scope/channel_scope_gain ;
            break;
    if(channel==2)
            for(i=0;i<Channel1.pointnum;i++)
                    data[i*2]=Channel1.data;
                    data[1+i*2]=Channel2.data;
int CVICALLBACK detection (int panel, int control, int event,
{   int  iPanel;
        switch (event)
                case EVENT_COMMIT:
                         if((iPanel=LoadPanel (0, "asp.uir", PANEL_2))<0)
                                 return -1;
                    InstallPopup (iPanel);
                        break;
        return 0;
还有就是,我在一个窗口里面有两个面板,但是只有一个面板的程序,请问怎么生成另一个面板的程序呢?而且是把两个程序加在一起的那种?
发表于 2007-5-19 21:38:55 | 显示全部楼层
用installpopup()函数安装你的检测面板(即灯显示面板).在原先产生信号的函数后面,添加点亮灯的函数即可。然后在该面板的关闭函数中用removepopup()函数即可转回原先的面板(控制信号面板)。不知答复是否满意?
 楼主| 发表于 2007-5-21 08:22:40 | 显示全部楼层
 楼主| 发表于 2007-5-21 08:31:42 | 显示全部楼层
int CVICALLBACK start (int panel, int control, int event,
             int value ;
        switch (event)
                case EVENT_COMMIT:
                 break;
     return 0;
int CVICALLBACK QuitCallback1 (int panel, int control, int event,
        switch (event)
                case EVENT_COMMIT:
                         DiscardPanel(panel);
                        break;
        return 0;
int CVICALLBACK select (int panel, int control, int event,
    switch (control)
        break;
    return 0;
int CVICALLBACK change (int panel, int control, int event,
        switch (event)
                case EVENT_COMMIT:
                        break;
        return 0;
我想在select里面有三个选项,在点start之后,如果选在第一个选项就是前3个灯亮。要是第二个选项就是最后两个灯亮,如果是第三个选项就是是前5个灯亮。可以帮我实现么?感激不尽......谢谢
发表于 2007-5-21 18:48:17 | 显示全部楼层
对你的描述不是很明白,抱歉,帮不上什么忙啊!呵呵
 楼主| 发表于 2007-5-22 07:47:55 | 显示全部楼层
select是个旋转开关,通过旋转来实现不同的灯亮。然后一按start就开始亮灯了
明白么? 嘿嘿
在帮帮忙看看吧?
发表于 2007-5-22 22:39:26 | 显示全部楼层
int CVICALLBACK startcb (int panel, int control, int event,
        switch (event)
                case EVENT_COMMIT:
                        GetCtrlVal (panelHandle, PANEL_RINGKNOB, &value);
                        switch (value)
                                case 0: //在点start之后,如果旋转开关选在第一个选项就是前3个灯亮。
                                        //此处只是让不用的灯显示灰色,在产生信号的面板
                                        // 让可以显示的灯判断信号状态
                                         SetCtrlAttribute (panelHandle, PANEL_LED, ATTR_DIMMED, 1);
                                         SetCtrlAttribute (panelHandle, PANEL_LED_2, ATTR_DIMMED, 1);
                                         SetCtrlAttribute (panelHandle, PANEL_LED_3, ATTR_DIMMED, 1);
                                         SetCtrlAttribute (panelHandle, PANEL_LED_4, ATTR_DIMMED, 0);
                                         SetCtrlAttribute (panelHandle, PANEL_LED_5, ATTR_DIMMED, 0);
                                         SetCtrlAttribute (panelHandle, PANEL_LED_6, ATTR_DIMMED, 0);
                                         SetCtrlAttribute (panelHandle, PANEL_LED_7, ATTR_DIMMED, 0);
                                        我想在select里面有三个选项,要是第二个选项就是,如果是第三个选项就是是前5个灯亮。可以帮我实现么?感激不尽......谢谢
                                        break;
                                case 1:    //在点start之后,如果旋转开关选在第二个选项就是最后两个灯亮。
                                        // 让可以显示的灯判断信号状态
                                        SetCtrlAttribute (panelHandle, PANEL_LED, ATTR_DIMMED, 0);
                                         SetCtrlAttribute (panelHandle, PANEL_LED_2, ATTR_DIMMED, 0);
                                         SetCtrlAttribute (panelHandle, PANEL_LED_3, ATTR_DIMMED, 0);
                                        SetCtrlAttribute (panelHandle, PANEL_LED_6, ATTR_DIMMED, 1);
                                         SetCtrlAttribute (panelHandle, PANEL_LED_7, ATTR_DIMMED, 1);
                                        break;
                                case 2:  // 在点start之后,如果旋转开关选在第三个选项就是前5个灯亮。
                                        // 让可以显示的灯判断信号状态
                                         SetCtrlAttribute (panelHandle, PANEL_LED_4, ATTR_DIMMED, 1);
                                         SetCtrlAttribute (panelHandle, PANEL_LED_5, ATTR_DIMMED, 1);
                                         SetCtrlAttribute (panelHandle, PANEL_LED_7, ATTR_DIMMED,0);
                                        break;
                        break;
        return 0;
前面板有一个旋转开关(三种状态 )。同时有七个状态灯 和一个按钮。
上述回答不知可以吗?
 楼主| 发表于 2007-5-23 07:42:20 | 显示全部楼层
GMT+8, 2026-9-28 19:21 , Processed in 0.042154 second(s), 8 queries , Gzip On, File On.
