查看: 1460|回复: 1
求助
发表于 2007-5-11 11:07:56 | 显示全部楼层 |阅读模式
我现在在做一个检测面板,图片在附件里,这个面板是虚拟信号输入面板,还有个检测面板没有做出来,不过现在遇到的问题是两个面板之间的连接转换,我试了很多次都不成功,很郁闷,希望高手同志帮忙指点下!谢谢
在有个问题,我这有三个通道,我的想法是输入三个信号传到下一个检测面板进行检测,希望各位帮我看看,能否实现,因为我第二个面板还没做出来。最好有程序给我研究下!谢谢
struct CHANNELDATA{
        int waveform;
        double frequency;
        double scope;
        int pointnum;
        double data[MAX_POINTS];
        }Channel1,Channel2;
static int handle;
static int panelHandle2;
int channel=0,channel_signal=0;
double channel_scope_gain=1.0,channel_frequency_gain=1;
int chartmode=1;//continue
int power=0;//off
//static int waveform=1;//sine
static double data[MAX_POINTS*2];
void GenerateData(void)  ;
int main (int argc, char *argv[])
        if (InitCVIRTE (0, argv, 0) == 0)        /* Needed if linking in external compiler; harmless otherwise */
                return -1;        /* out of memory */
        if ((handle = LoadPanel (0, "sample4_8.uir", PANEL)) < 0)
                return -1;
        DisplayPanel (handle);
        Channel1.frequency=1.0;
        Channel1.scope=1.0;
        Channel1.pointnum=512;
        Channel1.waveform=1;//sin
        Channel2.frequency=1.0;
        Channel2.scope=1.0;
        Channel2.pointnum=512;
        Channel2.waveform=1;//sin
        RunUserInterface ();
        return 0;
int CVICALLBACK DataFunc (int panel, int control, int event,
{   double signal_scope,signal_frequency;
        int waveform;
    switch (control)
   {case PANEL_SCOPEGAIN:
            if (event == EVENT_VAL_CHANGED)
                 GetCtrlVal (handle, PANEL_SCOPEGAIN, &channel_scope_gain);
            break;
        case PANEL_FREQGAIN:
                 GetCtrlVal (handle, PANEL_FREQGAIN, &channel_frequency_gain);
            break;
        case PANEL_SCOPE:
                if (event == EVENT_COMMIT)
        {GetCtrlVal (handle, PANEL_SCOPE, &signal_scope);
         if(channel_signal==0)
           Channel1.scope=signal_scope;
           else
            Channel2.scope=signal_scope;
        break;
        case PANEL_FREQUENCY:
        {GetCtrlVal (handle, PANEL_FREQUENCY, &signal_frequency);
            Channel1.frequency=signal_frequency;
          else
           Channel2.frequency=signal_frequency;
        break;
        case PANEL_WAVEFORM:
            {GetCtrlVal (handle, PANEL_WAVEFORM, &waveform);
        Channel1.waveform=waveform;
        else
        Channel2.waveform=waveform;
            break;
    return (0);
int CVICALLBACK ChartMode (int panel, int control, int event,
{int Mode;switch (event)
           {case EVENT_COMMIT:
        GetCtrlVal (handle, PANEL_CHART_MODE, &chartmode);
        switch(chartmode)
           {case 0: Mode=VAL_SWEEP;
        break;
        case 1: Mode= VAL_CONTINUOUS;
        break;
        case 2: Mode= VAL_BLOCK;
        break;
        SetCtrlAttribute (handle, PANEL_CHART, ATTR_SCROLL_MODE, Mode);
        break;
        return 0;
int CVICALLBACK Quit (int panel, int control, int event,
        switch (event)
        case EVENT_COMMIT:
        QuitUserInterface (0);
        break;
        return 0;
int CVICALLBACK SelectChannel (int panel, int control, int event,
        switch (event)
        case EVENT_COMMIT:
        GetCtrlVal (handle, PANEL_CHANNEL, &channel);
        break;
        return 0;
int CVICALLBACK Timer (int panel, int control, int event,
        int i;
        switch (event)
        case EVENT_TIMER_TICK:
        GenerateData();
        if(channel==0)
        PlotStripChart (handle, PANEL_CHART, Channel1.data, Channel1.pointnum, 0, 0, VAL_DOUBLE);
        if(channel==1)
        PlotStripChart (handle, PANEL_CHART, Channel2.data, Channel2.pointnum, 0, 0, VAL_DOUBLE);
        if(channel==2)
        PlotStripChart (handle, PANEL_CHART, data, Channel1.pointnum*2, 0, 0, VAL_DOUBLE);
        break;
        return 0;
int CVICALLBACK Power (int panel, int control, int event,
        switch (event)
        case EVENT_COMMIT:
        GetCtrlVal (handle, PANEL_POWER, &power);
        SetCtrlVal (handle, PANEL_LED, power);
        SetCtrlAttribute (handle, PANEL_TIMER, ATTR_ENABLED, power);
        if(power==0)
        ClearStripChart (handle, PANEL_CHART);
        break;
        return 0;
int CVICALLBACK ChannelSignal (int panel, int control, int event,
        switch (event)
        case EVENT_COMMIT:
        GetCtrlVal (handle, PANEL_CHANNELSIGNAL, &channel_signal);
        SetCtrlVal (handle, PANEL_FREQUENCY, Channel1.frequency);
        SetCtrlVal (handle, PANEL_SCOPE, Channel1.scope);
        SetCtrlVal(handle,PANEL_WAVEFORM,Channel1.waveform) ;
        else
        SetCtrlVal (handle, PANEL_FREQUENCY, Channel2.frequency);
        SetCtrlVal (handle, PANEL_SCOPE, Channel2.scope);
        SetCtrlVal(handle,PANEL_WAVEFORM,Channel2.waveform);
        break;
        return 0;
int CVICALLBACK Channel (int panel, int control, int event,
        switch (event)
        case EVENT_COMMIT:
        if(channel==0)
        SetCtrlAttribute (handle, PANEL_CHART, ATTR_NUM_TRACES, 1);
        SetTraceAttribute (handle,PANEL_CHART,1 ,ATTR_TRACE_COLOR, VAL_GREEN);
        if(channel==1)
        SetTraceAttribute (handle, PANEL_CHART,1, ATTR_TRACE_COLOR, VAL_RED);
        if(channel==2)
        SetCtrlAttribute (handle, PANEL_CHART, ATTR_NUM_TRACES, 2);
        SetTraceAttribute (handle, PANEL_CHART,1,ATTR_TRACE_COLOR, VAL_GREEN);
        SetTraceAttribute (handle, PANEL_CHART,2,ATTR_TRACE_COLOR, VAL_RED);
        break;
        return 0;
void CalculatePointNum()
        if(channel==0)
        Channel1.pointnum=1024/Channel1.frequency/channel_frequency_gain ;
        else if(channel==1)
        Channel2.pointnum=1024/Channel2.frequency/channel_frequency_gain ;
        else
        {   //SET SAME POINT
        Channel2.pointnum=1024/Channel1.frequency/channel_frequency_gain ;
void GenerateData()
        int i;
        CalculatePointNum();
        switch (Channel1.waveform)
        case 0:
                for (i=0; i<Channel1.pointnum/2; i++)
                Channel1.data =Channel1.scope/channel_scope_gain ;
                for (i=Channel1.pointnum/2; i<Channel1.pointnum; i++)
                Channel1.data =-Channel1.scope/channel_scope_gain ;
         break;
        case 1:
                for (i=0; i<Channel1.pointnum; i++)
                Channel1.data = sin (i*2.0*PI/Channel1.pointnum) * Channel1.scope/channel_scope_gain ;
          break;
        case 2:
                Channel1.data = ((rand()/23767.0) - 0.5) * Channel1.scope/channel_scope_gain ;
            break;
        switch (Channel2.waveform)
   case 0:
                for (i=0; i<Channel2.pointnum/2; i++)
                     Channel2.data =Channel2.scope/channel_scope_gain ;
                for (i=Channel2.pointnum/2; i<Channel2.pointnum; i++)
                     Channel2.data =-Channel2.scope/channel_scope_gain ;
            break;
        case 1:
            for (i=0; i<Channel2.pointnum; i++)
                 Channel2.data = sin (i*2.0*PI/Channel2.pointnum) * Channel2.scope/channel_scope_gain ;
            break;
        case 2:
                Channel2.data = ((rand()/23767.0) - 0.5) * Channel2.scope/channel_scope_gain ;
            break;
    if(channel==2)
            for(i=0;i<Channel1.pointnum;i++)
            {data[i*2]=Channel1.data;
            data[1+i*2]=Channel2.data;}
int CVICALLBACK detection (int panel, int control, int event,
        switch (event)
        { case EVENT_COMMIT:
         break;}
        return 0;
发表于 2007-6-26 10:02:09 | 显示全部楼层
两个面板之间的连接转换也许可以这样(仅供参考):
先把两个面板都装入(在MAIN函数里),先只显示信号输入面板,当按下"检测"按钮时,将信号输入面板隐藏,显示检测面板.关闭检测面板(其实只是隐藏)时,再将信号输入面板显示(DISPLAY)出来...
GMT+8, 2026-9-28 17:05 , Processed in 0.044082 second(s), 11 queries , Gzip On, File On.
