查看: 1840|回复: 0
研华818L的采集卡疑问!
发表于 2004-11-8 18:02:08 | 显示全部楼层 |阅读模式
我用的是研华818L的采集卡,下面是我编的一个DLL,但是在VC++下就是编译不能通过,
出错的地方是在(*arg3)->elt=arrayA这一句,大侠们救我一下!!!谢谢!!!
/* Call Library source file */
#include "extcode.h"
#include "hosttype.h"
#include "conio.h"
#include "stdlib.h"
/* Typedefs */
typedef struct {
        long dimSize;
        float elt[1];
        } TD1;
typedef TD1 **TD1Hdl;
_declspec(dllexport) void goal(unsigned short int *basea, long *samples, TD1
Hdl arg3);               //basea为板卡的基地址,sanmples为采用点数,,
Hdl arg3)
        /* Insert code here */
        short int dbyte;
        float value;
        short int i;
        float * arrayA;
arrayA=(float *) calloc (*samples,sizeof(float));
        (*arg3)->dimSize=*samples;
        (*arg3)->elt=arrayA;
        for(i=0;i<*samples;i++)
                _outp(*basea+1,0x00);     //这些为写和读板卡的端口
                _outp(*basea+2,0x00);
                _outp(*basea+0,0x00);
                while(_inp(*arg1+8)&0x00);
                dbyte=_inp(*basea+1)&0xff+(_inp(*basea+0)&0xf0)*256;
                value=(float)((dbyte)*10/4096-5);
            *arrayA=value;
                arrayA++;
GMT+8, 2026-9-28 09:04 , Processed in 0.027972 second(s), 6 queries , Gzip On, File On.
