楼主: cpubbs
P2P 之 UDP穿透NAT的原理与实现[转贴]
 楼主| 发表于 2005-6-28 20:35:39 | 显示全部楼层
Ford, Srisuresh & Kegel                                        [Page 25]
Internet-Draft     P2P applications across middleboxes      October 2003
[BIDIR]    Peer-to-Peer Working Group, NAT/Firewall Working Committee,
           "Bidirectional Peer-to-Peer Communication with Interposing
           Firewalls and NATs", August 2001.
           http://www.peer-to-peerwg.org/tech/nat/
[KEGEL]    Dan Kegel, "NAT and Peer-to-Peer Networking", July 1999.
           http://www.alumni.caltech.edu/~dank/peer-nat.html
[MIDCOM]   P. Srisuresh, J. Kuthan, J. Rosenberg, A. Molitor, and
           A. Rayhan, "Middlebox communication architecture and
           framework", RFC 3303, August 2002.
[NAT-APPL] D. Senie, "Network Address Translator (NAT)-Friendly
           Application Design Guidelines", RFC 3235, January 2002.
[NAT-PROT] M. Holdrege and P. Srisuresh, "rotocol Complications
           with the IP Network Address Translator", RFC 3027,
           January 2001.
[NAT-PT]   G. Tsirtsis and P. Srisuresh, "Network Address
           Translation - Protocol Translation (NAT-PT)", RFC 2766,
           February 2000.
[NAT-TERM] P. Srisuresh and M. Holdrege, "IP Network Address
           Translator (NAT) Terminology and Considerations", RFC
           2663, August 1999.
[NAT-TRAD] P. Srisuresh and K. Egevang, "Traditional IP Network
           Address Translator (Traditional NAT)", RFC 3022,
           January 2001.
[STUN]     J. Rosenberg, J. Weinberger, C. Huitema, and R. Mahy,
           "STUN - Simple Traversal of User Datagram Protocol (UDP)
           Through Network Address Translators (NATs)", RFC 3489,
           March 2003.
8.2. Informational references
[ICE]      J. Rosenberg, "Interactive Connectivity Establishment (ICE):
           A Methodology for Network Address Translator (NAT) Traversal
           for the Session Initiation Protocol (SIP)",
           draft-rosenberg-sipping-ice-00 (Work In Progress),
           February 2003.
[RSIP]     M. Borella, J. Lo, D. Grabelsky, and G. Montenegro,
           "Realm Specific IP: Framework", RFC 3102, October 2001.
[SOCKS]    M. Leech, M. Ganis, Y. Lee, R. Kuris, D. Koblas, and
Ford, Srisuresh & Kegel                                        [Page 26]
           L. Jones, "SOCKS Protocol Version 5", RFC 1928, March 1996.
[SYM-STUN] Y. Takeda, "Symmetric NAT Traversal using STUN",
           draft-takeda-symmetric-nat-traversal-00.txt (Work In
           Progress), June 2003.
[TCP]      "Transmission Control Protocol", RFC 793, September 1981.
[TEREDO]   C. Huitema, "Tered Tunneling IPv6 over UDP through NATs",
           draft-ietf-ngtrans-shipworm-08.txt (Work In Progress),
           September 2002.
[TURN]     J. Rosenberg, J. Weinberger, R. Mahy, and C. Huitema,
           "Traversal Using Relay NAT (TURN)",
           draft-rosenberg-midcom-turn-01 (Work In Progress),
           March 2003.
[UPNP]     UPnP Forum, "Internet Gateway Device (IGD) Standardized
           Device Control Protocol V 1.0", November 2001.
           http://www.upnp.org/standardizeddcps/igd.asp
9. Author's Address
   Bryan Ford
   Laboratory for Computer Science
   Massachusetts Institute of Technology
   77 Massachusetts Ave.
   Cambridge, MA 02139
   Phone: (617) 253-5261
   E-mail: baford@mit.edu
   Web: http://www.brynosaurus.com/
   Pyda Srisuresh
   Caymas Systems, Inc.
   11799-A North McDowell Blvd.
   Petaluma, CA 94954
   Phone: (707) 283-5063
   E-mail: srisuresh@yahoo.com
   Dan Kegel
   Kegel.com
   901 S. Sycamore Ave.
   Los Angeles, CA 90036
   Phone: 323 931-6717
   Email: dank@kegel.com
   Web: http://www.kegel.com/
Ford, Srisuresh & Kegel                                        [Page 27]
Full Copyright Statement
   Copyright (C) The Internet Society (2003).  All Rights Reserved.
   This document and translations of it may be copied and furnished to
   others, and derivative works that comment on or otherwise explain it
   or assist in its implementation may be prepared, copied, published
   and distributed, in whole or in part, without restriction of any
   kind, provided that the above copyright notice and this paragraph are
   included on all such copies and derivative works.  However, this
   document itself may not be modified in any way, such as by removing
   the copyright notice or references to the Internet Society or other
   Internet organizations, except as needed for the purpose of
   developing Internet standards in which case the procedures for
   copyrights defined in the Internet Standards process must be
   followed, or as required to translate it into languages other than
   English.
   The limited permissions granted above are perpetual and will not be
   revoked by the Internet Society or its successors or assigns.
   This document and the information contained herein is provided on an
   "AS IS" basis and THE INTERNET SOCIETY AND THE INTERNET ENGINEERING
   TASK FORCE DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING
   BUT NOT LIMITED TO ANY WARRANTY THAT THE USE OF THE INFORMATION
   HEREIN WILL NOT INFRINGE ANY RIGHTS OR ANY IMPLIED WARRANTIES OF
   MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE.
Ford, Srisuresh & Kegel                                        [Page 28]
GMT+8, 2026-9-29 00:20 , Processed in 0.023845 second(s), 7 queries , Gzip On, File On.
